Power Loss When Load Applied??? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-15-2012, 05:48 AM   #1
Power loss when load applied???
I have a weird situation that I can't figure out...Inside the garage there is a three way switch that powers the outside light. When testing without any load (wires exposed, light isn't connected), the switch seems to work properly; however, when I connect a motion sensing security light, power is lost and the switch doesn't seem to work...any ideas?
Thanks!
eugenefks is offline   Reply With Quote
Old 02-15-2012, 05:50 AM   #2
Julius793's Avatar
Thanks!
Faulty motion sensor?
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 02-15-2012, 05:51 AM   #3
Brand new unit. Installed elsewhere and works fine.
Old 02-15-2012, 05:51 AM   #4
Rewards Points: 506
What do you mean when you say power is lost?
jlmran is offline   Reply With Quote
Old 02-15-2012, 05:53 AM   #5
current* (using tester)
Old 02-15-2012, 05:54 AM   #6
Rewards Points: 506
What??
Old 02-15-2012, 05:58 AM   #7
Rewards Points: 506
It appears you've tested the switch and tested the light. You say both work. Have you tested the circuit for the presence of voltage?
Old 02-15-2012, 06:13 AM   #8
I tested the circuit (at the light location) using non contact current tester...I'll check for voltage with a multimeter today, but if voltage is good any other ideas what it could be?
Old 02-15-2012, 06:21 AM   #9
Rewards Points: 506
Bad bulb?
Old 02-15-2012, 06:35 AM   #10
Bad bulb?
no...
Old 02-15-2012, 06:50 AM   #11
Rewards Points: 3,256
Do you have a neutral at your light location to power the motion detector?
It would be a wirenutted unused wire in your box.
zappa is offline   Reply With Quote
Old 02-15-2012, 06:51 AM   #12
Rewards Points: 1,494
Does a different (perhaps non-motion sensing) light work in the circuit?
A severe voltage drop when you try to use something (you apply a load) usually means a loose connection somewhere upstream.
Voltage staying the same but the light or other equipment does not work usually means a problem downstream of where you are testing.
Do not measure the voltage across two switch terminals. Although there are some uses for this, this does not produce useful results here. Measure voltage from neutral to each desired point of interest.
Old 02-15-2012, 07:05 AM   #13
Rewards Points: 506
Clamp style? And it showed current flow?
Old 02-15-2012, 07:13 AM   #14
Well the wires are old with fabric/asbestos wrapping which is all faded now, but when testing only one was hot. I'm assuming the other was neutral?
Thank you!
You recommend checking connections at the switch box? Maybe changing the switch? If that doesn't work - I may just run a separate line all together only for this light, but this is my last reserve.
Old 02-15-2012, 07:25 AM   #15
Nevermind...I'm not sure where my head is this morning.
You should have a neutral up there.
Intermittent Brief Power Outages in Half the House mac70pete Electrical 11 06-02-2011 09:35 PM
Project adding 3-phase power to a tenant finish project bnharbor Electrical 5 11-11-2010 05:39 AM
sudden power loss duster Electrical 3 04-08-2010 05:14 PM
Grid power loss indicator ? Roy Rowlett Electrical 1 03-20-2010 09:53 PM
ceiling light power loss pejay Electrical 4 08-22-2008 05:02 AM
