Power To Light But Not Vent Fan - Electrical - DIY Chatroom Home Improvement Forum
Old 10-04-2013, 03:05 PM   #1
Power to light but not vent fan
Hello all! I just bought a house and during inspection, the bathroom fan would turn on. The inspector required an electrician to install an additional breaker due to one breaker being double tapped. The panel only has three of the breakers labeled so I am not sure which breaker was double tapped and if it had anything to do with my problem, but after closing I found out that the fan quit working. I tried plugging something in to the plug-in in the fan housing and there is no power to it so I thought the switch went bad. I installed a new switch with no luck. I bought a non-contact voltage tester and the entire light/fan switch box appears dead. However, the switch for the light turns the light on and off. There is also a plug on the light fixture (convenient) which Does show current running to it, whether the switch is on or off And the Light switch supplies power to the fan switch, or so it appears. It is very frustrating
I realize I should just call the electrician that worked on the panel to check it out but I thought I would try figuring it out on my own before spending a bunch on money on the electrician.
Does anyone have any suggestions to try? I will try to get a picture tonight if that would help?
Thank you in advance!
Ryan
rblades is offline   Reply With Quote
Old 10-04-2013, 05:29 PM   #2
Rewards Points: 150
Well if it worked before the electrician did his work, then it's more than likely something the electrician did
romex1220 is offline   Reply With Quote
Old 10-04-2013, 06:00 PM   #3
dmxtothemax's Avatar
Rewards Points: 5,370
Are you sure that the fan was working,
before the electrician put in the new breaker ?
Is the fan switched seperately from the light ?
Does the light work ?
If neither work, then check for power at switchs,
Then if nessecary check at breaker or nearest recepticule.
dmxtothemax is online now   Reply With Quote
Old 10-04-2013, 06:46 PM   #4
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Why install a new breaker? Just simply make a splice to avoid two wires under one screw.
Old 10-09-2013, 08:39 PM   #5
Rewards Points: 170
Post a pic of the switch box opened up... would help allot. Thanks
diyer111 is offline   Reply With Quote
Old 10-09-2013, 09:10 PM   #6
Master Electrician
Rewards Points: 3,874
You must not be aware of what some of those home inspectors come up with. It can be truly amazing.
http://www.inspectionnews.net/home_i...al-inspection/
brric is offline   Reply With Quote
Water heater, atomospheric vent or power vent? abefroman Plumbing 5 01-24-2013 10:56 AM
Power failure light gotyer6 Electrical 10 06-23-2011 06:31 AM
Ridge vent and power vent neikorott Roofing/Siding 1 09-09-2010 05:57 AM
Grabbing power from a light switch box RedBear Electrical 3 01-13-2010 01:28 PM
Repair or replace gas heat unit and power vent PegTN HVAC 1 11-06-2009 06:40 PM
