Power Issue - Electrical - DIY Chatroom Home Improvement Forum
Old 05-02-2010, 02:15 PM   #1
Power issue
My lights keep flickering and my power restarts every few days, what could be the problem?
Any suggestions?
Vbort44 is offline   Reply With Quote
Old 05-02-2010, 02:31 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
Loose wire.
Bad connection.
Corroded service cable.
Problem at the POCO transformer.
Could be many things.
This is obviously an ongoing problem. Have you called anyone to look at it yet???
Speedy Petey is online now   Reply With Quote
Old 05-02-2010, 04:16 PM   #3
No, I haven't called anyone in yet, I thought I'd first see if I could get some initial thoughts. I guess I should just call in an electrician and go from there?
Old 05-02-2010, 04:28 PM   #4
Also, just called around for someone. One guy said, $125/hr (licensed electrician) and another said $65 (contractor). Is it important to have a licensed electrician for my situation?
Old 05-02-2010, 04:34 PM   #5
Journeyman Wireman
Rewards Points: 150
It the problem is a whole house problem, I would start by calling the POCO and describing the issues. Ask the neighbors if they are having any problems which might indicate a problem at the transformer. They might even pull your meter to check the connections there. If they don't find anything, then call an electrician.
I've had three recent service calls where the problem was a POCO problem, fixed by the POCO for no charge, but the customer still had to pay me for my time to inspect/troubleshoot the interior wiring even though I didn't find any problems.
Jupe Blue is offline   Reply With Quote
Old 05-02-2010, 04:36 PM   #6
Journeyman Wireman
Rewards Points: 150
Yes, you want someone who is licensed and who knows what they are doing. I'm not sure what the word "contractor" means in your area. Can a contractor even do electrical work legally?
PS. In regards to my previous post, you might even be able to get the POCO out on a Sunday to check your service drop.
Old 05-02-2010, 09:02 PM   #7
Thanks JP, I'll first have the POCO come out and see how that goes - cheers.
Old 05-02-2010, 09:18 PM   #8
POCO should be the first call.
I am also not sure what the difference between a licensed guy and a contractor is. I would hope they were the same.
Every area has it's own way of doing things.
Power Save Device capt2 Electrical 52 02-24-2010 07:42 PM
Can I give 12V DC to power inverter through PC Power supply? inverter General DIY Discussions 3 07-06-2009 10:38 AM
Amp meter Results - SE Cable Bad or Power CO jamiedolan Electrical 30 01-23-2009 01:16 AM
safe way to add extension to power cord sil Electrical 7 10-18-2007 10:58 PM
