Power Inverter - Electrical - DIY Chatroom Home Improvement Forum
Old 02-23-2010, 10:03 PM   #1
Power Inverter
This might be a stupid question and I think I already know the answer but I wanted to make sure. I have this power inverter and It immediately trips as soon as I turn it on. My question is should I have continouity from neutral to hot. Of course no batteries are hooked up when I do this test. As it stands now I do have continuity. I shot line voltage through it one night on accident when i was testing something and think that contacts inside arced together and maybe causing my overload. Any thoughts?
Livewire78 is offline   Reply With Quote
Old 02-24-2010, 01:03 AM   #2
Inverters are designed many different ways. With some which are working perfectly fine you could measure from hot to neutral when not on and get no continuity. Others continuity.
The way to test it would be to have the schematic diagram, know electronics, and use a multimeter and oscilloscope.
Billy_Bob is offline   Reply With Quote
Old 02-24-2010, 08:32 AM   #3
Rewards Points: 1,548
So now the batteries are installed and nothing is plugged into the output (120 volt receptacles) and the inverter trips when you flip its power switch on?
From what you told us, I think the inverter is fried. History.
The normal and also easy checking of an inverter is done by measuring volts (between hot and neutral) at the output. Plugging in a small light also does the trick. When your inverter tripped immediately, the preceding test is deemed to have failed.
Turn off power before doing continuity tests. With an inverter, where to do continuity checks and how to interpret the results (and also find out exactly what got fried) requires a good amount of electrical know-how.
How do I get power to a new ceiling fan? sestivers Electrical 15 10-10-2016 04:16 PM
Can I give 12V DC to power inverter through PC Power supply? inverter General DIY Discussions 3 07-06-2009 09:38 AM
Power inverter AndrewL Electrical 6 03-02-2008 01:43 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 01:55 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 10:23 PM
