Power Inverter - Electrical - DIY Chatroom Home Improvement Forum
Old 03-02-2008, 09:03 AM   #1
Power inverter
Hello, I have quite a odd technical power question.
I want to run a computer from a car battery. So it is portable. But I need to get maximum time use of the battery. So I was wanting to know would it be best to run a 24v to 240v 1000w converter to power the screen and computer or put a 24v to 240v 100w converter to power the screen then built a power converter to directly power the system, straight off as DC. Or is there not much in it? Plus how complicated would it be to make a power supply for a pc that runs off a 24v battery?
I know this is probably the wrong place to ask, but when I ask on computer forums they give very blank looks, I was hoping there might be some better answers on here.
AndrewL is offline   Reply With Quote
Old 03-02-2008, 09:23 AM   #2
Crabby Bastard
terri_and_jj's Avatar
insert blank look here
wouldn't a laptop with an extended battery make more sense? desktops and monitors aren't made to run off batteries for any length of time so they are power hogs compared to portables. Laptops are (obviously) designed for portability with power management and will give you a lot more run time .
terri_and_jj is offline   Reply With Quote
Old 03-02-2008, 09:28 AM   #3
Admittedly laptop would be more practical, and would be remarkably cheaper. It need the capabilities of a pc. I have looked into the options of having a laptop, and extending the battery, but it wouldn't work for what i need.
Old 03-02-2008, 09:48 AM   #4
I think you're more likely to get a good answer to your question at this forum: http://www.mp3car.com/vbulletin/
They have a FAQ about power supplies for car computers at http://www.mp3car.com/vbulletin/faq-...-part-1-a.html
Matsukaze is offline   Reply With Quote
Old 03-02-2008, 09:52 AM   #5
Thanks a lot, that is exactly the info I have been looking for.
Old 03-02-2008, 12:37 PM   #6
joed's Avatar
Rewards Points: 12,854
PCs and monitor run on 120 volts. No need for a 240 volt inverter. The length of run time you get is dependent on the power used by the PC/monitor and the size of the battery. The bigger the battery the longer the run time. The bigger and more powerful the PC the shorter the run time.
Old 03-02-2008, 01:43 PM   #7
What country are you in?
jerryh3 is offline   Reply With Quote
Help! Mystery power in complex 3-way! mnyman2003 Electrical 12 12-16-2007 01:10 PM
safe way to add extension to power cord sil Electrical 7 10-18-2007 09:58 PM
Need Advice (power Inverters for Ice Cream Truck) garagemaxx Electrical 4 05-15-2007 06:53 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 01:55 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 10:23 PM
