Power To Ground Wire - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-06-2012, 07:43 AM   #16
Power to ground wire
Thank you everyone one who attempted to help me. Called a different Electrician, they will be here later this week.
mom5va is offline   Reply With Quote
Old 08-15-2012, 08:03 PM   #17
Smile
I found the problem and thought I should share the answer! In the bedroom that had power there is a double outlet set up for a computer or other electronics. These 2 outlets were wired to the same power in. HOWEVER one of them was actually tied into the hall circuit. So when the power was on in the bedroom current was traveling though the ground wires. Once I separated this outlet from the bedroom power everything worked fine.
The Following User Says Thank You to mom5va For This Useful Post:
gregzoll (08-15-2012)
50 Amps for a garage help IcyShadowz Electrical 48 05-31-2012 11:58 PM
Adding a ground wire to a fixture? dkeith Electrical 2 06-01-2011 09:08 PM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 04:30 PM
Is using a ground wire as neutral wire safe? Head Fred Electrical 9 12-18-2008 03:37 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
