Power Fluctuations? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-12-2009, 10:39 PM   #1
power fluctuations?
I experience what could be best described, by me, as power fluctuations in my condo. With appliances (fridge, bath exhaust fan, etc), it appears to come and go, but the normal operating sounds crescendo up and down, in a non stop loop. It doesn't appear to have anything to do with anything else that might be drawing power. I have had it happen with the simple exhaust fan in the bath, when it is the only thing on in the entire apt.
I also experience this with two, six inch, recessed lights in my kitchen, on incandescent bulbs. It happens any time I utilize these lights, even when they are the only thing on in the apt. It is also a constant loop, where the bulbs brighten, and then dim back to normal levels, maybe separated by a few seconds each time.
The buildings are around 30-40 years old. And the power is underground. A few people I know here, have terrible power situations. But overall, I think I am lucky. I can run most everything, without any trips. The outside lights on the property also appear to be just fine. We do have a lot of outages though...
Any ideas?
thanks
mrgoodkat is offline   Reply With Quote
Old 07-12-2009, 11:55 PM   #2
The first place I'd start, since others in the vicinity are experiencing similar problems, is your electric utility. Several causes are possible including voltage regulator relays used to protect the power lines of the distribution lines in your area needing adjustment or replacement the utility or a loose neutral connection at the utilities transformer.
Noel is offline   Reply With Quote
Old 07-13-2009, 09:29 PM   #3
Thanks for the response.
Nobody that I know is experiencing the same problems. They have issues with breaker tripping. However they are in differnt buildings too. And I dont currently know anyone in my building...
I should have specified.
I will contact the PC though.
Old 07-13-2009, 11:00 PM   #4
Thanks for the info
It might be a good idea to talk with the other occupants in your building and comparing notes. In the mean time, those recessed can lights....are they on a dimmer? If so, are the lights constantly run at one setting?
Old 07-14-2009, 11:27 AM   #5
Bad neutral?
Old 07-14-2009, 07:23 PM   #6
Rewards Points: 1,534
You should take voltage measurements, leaving the voltmeter connected in one place while these flucutations go on. Then measrue in another place, etc.
I would actually start measuring at the electrical panel, say, between neutral and one of the branch circuit wires attached to a circuit breaker.
If voltage goes above 130, chances are you have a problem with neutrals.
Voltage fluctuations at individual receptacle or lights but not at the panel suggest loose connections in the wiring.
AllanJ is online now   Reply With Quote
Old 07-14-2009, 09:47 PM   #7
Yes, the cans on a dimmer. I just moved in this summer, so I didn't notice, but the 'dimming' appears to be gone, or lessened greatly when I turn them higher.
I have called ComEd (chicago). And they are supposedly going to test the power coming in, at the panel.
Either way, I will check back in when i find out what it was.
thanks
Wring for Lincoln Power Mig Welder vstoyko Electrical 17 01-15-2009 06:15 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
safe way to add extension to power cord sil Electrical 7 10-18-2007 09:58 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 01:55 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 10:23 PM
