Power Flickering Problems - Electrical - DIY Chatroom Home Improvement Forum
Old 08-29-2014, 05:46 PM   #1
Power flickering problems
I am having a problem with losing power to my house for a second or two and then coming back on (this is a problem with the power company not being reliable) The reason this is a problem is because I have a large dehumidifier under my house that after being shut down needs to rest at least 10 minutes before being started back up. Is there a breaker out there that will trip on loss of voltage? I need some way to keep the dehumidifier from being powered right back up after a loss of voltage.
wphays is offline   Reply With Quote
Old 08-29-2014, 05:59 PM   #2
dmxtothemax's Avatar
Rewards Points: 5,600
Look for a "Power fail relay".
You will probably have to go to a electrical supply shop.
I don't think HD would stock them.
dmxtothemax is offline   Reply With Quote
Old 08-29-2014, 07:56 PM   #3
DIY staff
Rewards Points: 7,174
A magnetic switch like my table saw switch would also work---when the power shuts down the switch defaults to 'off' so the saw can not start up unexpectedly.
Grizzly Tool company has a nice selection.
Flickering Lights / Fluctuating Power from Outlets lizardpie Electrical 10 03-28-2013 07:17 PM
Trailer Trash Main Power Problems Spitfire_onme Electrical 84 02-12-2013 06:48 PM
Add more power to the house? (kinda long) tmtrebor Electrical 5 04-30-2010 03:19 PM
Flickering Power Saver Bulb stevebooker Electrical 10 02-02-2009 08:33 AM
Furnace power up problems Capaz HVAC 6 12-06-2006 12:26 PM
