#1 |
Power disconnect switch
I was looking at a book on well pumps and they show a power disconnect switch located near the pressure tank.Now my dad will be relocating my pressure tank and I do see a disconnect switch in the basement that the wire passes through on its way from the breaker box to the pressure switch.Don't want to sound stupid but what is it for.I mean if work needs to be done on the system throwing the breaker would kill all power so curious what the disconnect is for.This is a really a old house maybe they aren't used anymore.
#2 |
Long-Time DIYer
A disconnect switch at a water pump, an HVAC unit, etc. is just for that...a disconnect at the work site to prevent having to go all the way back and forth to the electrical panel when working on it.
Unless it's required by code where you're located, it is your option. Personally, I just have a duplex receptacle to plug and unplug the pump in to for a "disconnect", which is all that most people around here use. Simpler and serves the same purpose for a shallow well setup, but a disconnect would be needed for a deep well with a submersible pump down in it. Good Luck! Mike Last edited by Mike Swearingen; 03-28-2006 at 04:20 AM. |
| Display Modes | |
| Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) | inspectator | Electrical | 8 | 08-07-2007 02:19 AM |
| Switch Wiring | williamp | Electrical | 11 | 06-14-2007 08:40 PM |
| Help a hungover guy clear his head. 3 way switch with pic | J187 | Electrical | 10 | 11-10-2006 09:10 PM |
| Detached garage adding a 3 way switch. | Slatherd | Electrical | 4 | 01-02-2006 03:53 PM |
| New Switch / Ceiling Fixture - Help | nelrolo3 | Electrical | 1 | 03-12-2004 07:11 PM |
