-   -   Power Cord fastners (http://www.diychatroom.com/f18/power-cord-fastners-165406/)
doc_63 12-02-2012 06:46 PM
Power Cord fastners
1 Attachment(s)
I hung a new light fixture yesterday and used these fastened to run the cord along the wall to clean it up. I didn't hard wire it so it goes to a plug in and has a switch on the end of the plug. These say they are for low voltage but is this ok as long as the cord isn't crimped tightly in the fasteners?
Attachment 61348
gregzoll 12-02-2012 07:52 PM
You should be fine with that.
doc_63 12-02-2012 08:02 PM
Thanks for the reply. I thought it would be ok but the fasteners were specified for low voltage. Maybe because that's what they typically get used for. Thanks again.
gregzoll 12-02-2012 08:34 PM
Yes, typically for Coax & Cat-5e/Cat-6, but to hold the power cord out of the way, you will be fine. It still makes it a temporary installation, since the cord is not permanently installed, same as the fixture.
Jim Port 12-02-2012 08:36 PM
Flexible cords should not be fastened to the building surfaces.
jbfan 12-02-2012 08:37 PM
What kind of light is ist?
gregzoll 12-02-2012 09:44 PM
I really would not consider that as fastened to the building surface. It is more of just held by the coax/ethernet clips. You can actually pull on the cord, and it will come loose from under those clips.
doc_63 12-02-2012 11:19 PM
2 Attachment(s)
Attachment 61351
Attachment 61352
It's a track light. It has an adapter that snaps into the end of the track with a power cord attached to it. The fasteners aren't pounded in tight if that matters.
gregzoll 12-03-2012 07:50 AM
Since the power cord was is for a temp use only, and since this is track lighting, I would go with something like http://www.lowes.com/pd_193256-35681...ems&facetInfo= and the proper box, that will allow you to pull Romex for permanent use, if that fixture is staying.
doc_63 12-03-2012 08:24 AM
Romex isn't an option. The track light kit comes with the adapter that contains the power cord shown in the photos. The adapter slides and snaps right into the end of the track. Then the cord shown is attached to the adapter permanently and plugs into the wall on the other end. I did however consider this hiding option but I had these fasteners and thought they might work. How is one better than the other? Other than a cleaner look?
Thanks for the replies guys. You're knowledge truly helps us DIY'ers.
