Power Consumption In A Power Strip. - Electrical - DIY Chatroom Home Improvement Forum
Old 06-03-2011, 11:24 PM   #1
Question
Power consumption in a power strip.
Hi,
Isn't there a practical limit on how many sockets you can have in a power strip ?
Given that AC power is P=VI(cosφ), each socket in the strip will consume P supplied from one single wall socket. That means, the wall socket will have to deliver as much current as required by all the sockets in the strip. And, therefore, the number of sockets that can be supported is dependent on the number of Ampere limit of a house-hold.
Is this correct ?
AC230V50Hz is offline   Reply With Quote
Old 06-04-2011, 01:34 AM   #2
Semi-Pro Electro-Geek
Rewards Points: 2,852
The sockets themselves don't consume any power, only loads actually connected to them. Whatever loads are plugged into the power strip are all aggregated onto the one plug for the power strip. So, it's easy to overload a power strip by plugging in too many high-current loads. If all of the loads are low-current (like DC adapters or small battery chargers, for example), then it's not a problem.
So there is no practical limit on how many receptacles there can be, only on how much total load can be connected.
mpoulton is offline   Reply With Quote
Old 06-04-2011, 09:34 AM   #3
I=E/R
a7ecorsair's Avatar
Keep in mind that the power strip is plugged into a conventional receptacle that has a current limit determined by the breaker protecting that circuit. Also, the power strips available on today's market all have a circuit breaker so the current draw to the strip is limited by this device.
a7ecorsair is offline   Reply With Quote
Old 06-04-2011, 09:35 AM   #4
zpm
yeah, right
Maybe things work differently for those 50 cycle types.
Honey, does this tool belt make me look FAT?
zpm is offline   Reply With Quote
Old 06-04-2011, 11:08 PM   #5
Cool
Thanks.
But, of course.
Yes. But, if there were no circuit breakers in the power strip, then the power strip cannot be drawing arbitrarily huge amperes of current without tripping the MCB. So, I wanted to know, can I calculate that ampere limit ?
Old 06-05-2011, 12:46 AM   #6
It's whatever the rating of the circuit breaker for that branch circuit is, less any other loads on the circuit. So if it's a 15A circuit, then your power strip can use up to 15A, less any other loads. Maybe I'm misunderstanding the question?
Old 06-05-2011, 05:38 AM   #7
Rewards Points: 1,192
Flip it over and look at the spec.label.
bobelectric is offline   Reply With Quote
Old 06-06-2011, 01:36 AM   #8
Perhaps, I am not writing the question correctly.
The wall socket would deliver 230 V AC at 5 A. If I plug in a power strip to the wall socket, with sockets in power strip, each requiring to deliver 230 V at 5 A, then how many such sockets can I have in my power strip ? I think, the limit is applied by the fuse in the power strip. That would mean, the actual ampere value is determined by whatever is the specification for that power strip.
Now, for argument sake, if I have a power strip with no fuse, then the limit is applied by MCB of the house (assume no other electrical load in house). If so, then the actual ampere value is determined by whatever is the specification for house MCB. Is this correct ?
Old 06-06-2011, 01:55 AM   #9
Rewards Points: 506
A 15 amp circuit breaker will handle up to 15 amps (that's 1400 W after an 80% Derating) P= I*E where E=120v (not 230), and I=15a
Old 06-06-2011, 04:00 AM   #10
The individual sockets in the power strip can each supply the full capacity of the circuit (all 5A, or whatever) - but that will only happen if you plug a load into one of them that actually draws the full current. Usually the loads are much smaller, so you can run many loads at a time on the circuit (hence the need for a power strip - to plug in many small things at once). So there is no limit on how many sockets you can have, only a limit on the total load you can plug into them.
Old 06-06-2011, 08:42 AM   #11
Licensed electrician
Rewards Points: 996
The voltage and frequencies are typical for a European system.
Old 06-06-2011, 08:55 AM   #12
joed's Avatar
Rewards Points: 11,516
If I understand correctly then you can only use one socket.
You are limited to 5 amps by the socket fuse. You can only plug in one 5 amp load in the power strip.
Tags
power strip , watts
Project adding 3-phase power to a tenant finish project bnharbor Electrical 5 11-11-2010 06:39 AM
Amp meter Results - SE Cable Bad or Power CO jamiedolan Electrical 30 01-23-2009 01:16 AM
Wring for Lincoln Power Mig Welder vstoyko Electrical 17 01-15-2009 07:15 PM
Old refrigerator = high power consumption? RammsteinNicCage Appliances 6 06-13-2008 11:50 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 11:23 PM
