Power Consumption To Heat An Area - Electrical - DIY Chatroom Home Improvement Forum
Old 03-27-2013, 11:08 AM   #1
Power consumption to heat an area
Wich would be the power consumption to heat an area of 162000 sf in kW? A warehouse
I came up with this amount of kWatts, could it be possible 1,424 kW/hrX 8 hours 11,392 kwattas a day, aren't too many kWs?
And I would aslo need to know how many months of the year the heating has to be used if the warehouse is located in tennese and how many if the warehouse is located in Ohio
Rgds
gloria saenz is offline   Reply With Quote
Old 03-27-2013, 04:24 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
With all due respect...how the bleep should we know?
The Following 3 Users Say Thank You to k_buz For This Useful Post:
jbfan (03-27-2013), Speedy Petey (03-27-2013), stickboy1375 (03-27-2013)
Old 03-27-2013, 04:30 PM   #3
Rewards Points: 13,300
You need to be in contact a few HVAC contrators to size this for you.
Anything else will just be guessing.
No one here can see your building, you did not even add your location to your profile, no one know how well insulated, what type of windows, exposure to the sun Ect.
Old 03-27-2013, 04:40 PM   #4
Always learning...
fetzer85's Avatar
Rewards Points: 262
Wow...we need so much more info.
What's the height of the roof? Going to cost a lot more to heat a given area if it's 25ft high vs. 15ft high.
Are the walls or roof insulated? Windows? Large openings/garages/bay doors? What kind of heaters, how many, where are they placed...
As Joe said, contact HVAC tech for a legit answer.
fetzer85 is offline   Reply With Quote
Old 03-28-2013, 12:09 AM   #5
" Euro " electrician
frenchelectrican's Avatar
Rgds
The only thing I will say it will be cheaper to run the heating equiment on gaz instead of electrique heating system.
Merci,
Marc
Heat pump not working properly after hurricane power outage phuz HVAC 26 11-06-2012 09:21 PM
Heat pump heat strip has power when hot leads are disconnected? pigdog HVAC 5 12-06-2011 12:00 AM
Heat pump starts initially but will not come back on to maintain temps johnniebravo HVAC 53 11-22-2011 08:48 PM
Power consumption in a power strip. AC230V50Hz Electrical 11 06-06-2011 08:55 AM
Old refrigerator = high power consumption? RammsteinNicCage Appliances 6 06-13-2008 11:50 PM
