-   -   Power and Com wires in the same conduit (http://www.diychatroom.com/f18/power-com-wires-same-conduit-177216/)
ppatenaude 04-15-2013 12:12 PM
Hello,
I'm in British Columbia and I have a question about running communication cables in the same conduit as power.
I know it is against code, but, is it ok to run shielded coax cable that carries RF and low voltage up to 90V with regular 220V power line, as long as the shielded coax is grounded at either end. Is this passible by BC code or not.
The conduits are 1.5 to 3 inch depending on the locations. The longest run would be 150m.
joed 04-15-2013 12:34 PM
It is only OK if the non power wires have an insulation rating equal to the power wires. That is they need to be 600 volt rated insulation.
ppatenaude 04-15-2013 01:20 PM
Thank you very much, and that makes sense. I just need to find such a cable, I have emailed a communication cable rep to see if there is such a cable,
Thanks again.
joed 04-15-2013 06:07 PM
Why can't you just run a second conduit for the comm wires?
ppatenaude 04-19-2013 11:58 AM
The existing conduits are under the road in intersections.
