Power Circuits Under Leaky Bathtub? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-23-2007, 06:40 AM   #1
Power circuits under leaky bathtub?
We're renting a home that has a leaky ground floor bathroom. We first notified the landlord two months ago, and we're going to call them again today. However, I've since noticed something which worries me: there are two power circuits in immediate proximity to the leak. The lines are in the floor beneath the tub, and visible from the open basement ceiling. One line presses up against the tub drain pipe. The other line, a 220v circuit for the dryer, runs directly under the leak path. Both circuits appear to be older wiring with black weave insulation of some type. Am I right to be concerned about these circuits, or am I worrying too much?
Beren is offline   Reply With Quote
Old 07-23-2007, 09:02 AM   #2
RippySkippy's Avatar
No you should be worried...call a raise heck with the land lord. If the owner won't do anythig, do you have a housing authority in your area that could assist you?
RippySkippy is offline   Reply With Quote
Help with ID'ing bathtub sound... DIY-Gal Plumbing 12 02-10-2007 05:45 AM
One neutral for two circuits?? TronCarter Electrical 13 01-14-2007 08:21 AM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 01:55 PM
Three electricans said it was impossible! Tom Electrical 35 04-29-2006 05:06 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 10:23 PM
