Power Cable Wire Nutted In Return Duct Not In Box - Electrical - DIY Chatroom Home Improvement Forum
Old 07-11-2013, 11:06 PM   #1
Rewards Points: 83
Power cable wire nutted in return duct not in box
Hi I have recently found a 12/2 cable running in my return air duct that is just connected with wire caps and not in a box. Someone who remodeled the house moved the receptacle a foot to the left and just wire nutted the wires that used to go into the old recptacle and pushed them back into the return duct. The air return duct is a stud bay being used as a return air duct that goes down into the lower floor joists. I have a small stud bay directly to the side with a two gang switchbox. This is were the cable originates from and then travels through a hole in the stud and into the air retun stud bay where the put the new recptcle, then a foot down the line it is junctioned with the wire nuts then continues up a stud and out the top of the bay into the attic. I would like to bypass the air return by pulling the cable back into the neighboring bay that has a 2 gang switchbox and put the receptacle there. Then cut the cable that comes out of the top of the air retun duct and remove that unused cable out of the return if possible. I would then fish a cable down the switchbox studbay to the receptacle and junction the the circuit in the attic. I have found where the cables exit the switchbox studbay and one of the holes has room for one more cable to slide in. Is it ok to put (2) 12/2 cables that are on seperate circuits through the same hole in the top plate if it will go up into/through cellulose insulation? They will go seperate ways immediatley after exiting the hole in the toplate.
pex006 is offline   Reply With Quote
Old 07-11-2013, 11:27 PM   #2
Rewards Points: 6,652
Well, looks like you are going to have to fix it, by pulling that wire into a junction box on the wall, so that it is properly terminated. It is fine being in the return duct, as long as it is not penetrating sheet metal.
Or do what you are thinking, and pull it down to place into a ceiling mounted junction box, then run a length to the outlet.
Old 07-11-2013, 11:47 PM   #3
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Running NM thru cold air returns is not legal unless going straight thru.
The Following User Says Thank You to k_buz For This Useful Post:
Gac66610 (07-11-2013)
Old 07-12-2013, 12:04 AM   #4
Electrical Enthusiast
Rewards Points: 504
What are the reasons this isn't allowed? Just for my own knowledge.
Is it considered a fire hazard ?
Kyle_in_rure is offline   Reply With Quote
Old 07-12-2013, 12:10 AM   #5
k_buz's Avatar
Ease of fire spreading.
Kyle_in_rure (07-12-2013)
Old 07-12-2013, 12:16 AM   #6
Resi EC
Rewards Points: 252
Is Burning Wire Illegal? | Scrap Metal Junkie
http://www.scrapmetaljunkie.com/873/...g-wire-illegal Cached
Burning wire releases carcinogens/toxins into the air and into the ground around the ... the money you make by burning copper wire is not worth the risk of burning it!
Just did a quick search on it, imagine a poor connection that catches the paper in NM on fire.
The toxins could spread easily through trunk lines (return or supply)
If at first you don't succeed .... do not work on live electrical
Gac66610 is offline   Reply With Quote
The Following User Says Thank You to Gac66610 For This Useful Post:
Old 07-12-2013, 12:41 AM   #7
Rewards Points: 504
That was guess #2
Old 07-12-2013, 12:54 AM   #8
" Euro " electrician
frenchelectrican's Avatar
Oui and the least amout of NM cable is exposed the chance of get on fire is reduced.
The most common cuprit I have get from time to time in USA side is when someone poke a hole and not too carefull with sheetmetal edge and it can cut which I found couple over the years.
The commercal side is very strict on this one that one reason why you genrally don't see NM much at all above the supened ceiling area due some case they used them as return penum area.
Merci,
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
Old 07-12-2013, 02:10 AM   #9
Rewards Points: 83
Thanks for the replies. So is it ok to put (2) 12/2 cables that are on seperate circuits through the same hole in the top plate if it will go up into/through cellulose insulation? They will go seperate ways immediatley after exiting the hole in the toplate. No derating required?
Old 07-12-2013, 06:46 AM   #10
k_buz's Avatar
That will be fine.
Old 07-12-2013, 01:57 PM   #11
Rewards Points: 83
Thanks for all your help. I really appreciate it.
Old 07-14-2013, 10:01 PM   #12
Rewards Points: 83
One more question. Do the two cables have to still have some wiggle room or is it ok that they are snug together. I have no trouble sliding the new cable in and back out by the other cable in the hole already, but they pretty much fill the hole completely when next to each other.
Old 07-14-2013, 10:48 PM   #13
What is the size of the box, and we can tell you what the fill ratio is for that box. Need Height, width, depth.
Old 07-14-2013, 11:20 PM   #14
Rewards Points: 83
This isn't into the box. I'm just asking about putting (2) 12/2 cables through the hole in the wood top plate of the studbay into the attic and if the two cables have to still have some wiggle room or is it ok that they are snug together. I have no trouble sliding the new cable in and back out by the other cable in the hole already, but they pretty much fill the hole completely when next to each other.
Old 07-14-2013, 11:41 PM   #15
Depends on what size of auger or spade bit you used to drill those holes. Most times I use a 1/2" bit for drilling holes through joists or plates. I have a 3/8" auger on my flex bit, that I use for pulling single wires through top or bottom plates.
3/8 is kind of tight for two Romex, unless you are using 12/3 or 14/3 Simplex pull, which is round, not flat, then you may be able to get it in there with enough space. It would be nice if they went away from the flat Romex, and went with the same style as Southwire uses for the 3 wire. Would make things a whole lot easier for pulling, and not having to drill large holes.
Adding a wall switch to a pull chain fixture abacuslearns Electrical 17 12-20-2011 07:02 PM
Using flex duct for return. lakeresident HVAC 3 11-14-2011 10:56 AM
ceiling fan wicked97 Electrical 4 08-21-2011 09:12 AM
Air duct return gallia HVAC 5 10-16-2010 01:52 PM
I really need help! POOK Electrical 34 04-20-2007 08:01 PM
