Old 09-15-2010, 11:09 PM   #1
Power
How can I grab power from a ceiling light that is controlled by a wall switch, or from an electrical outlet with one cable in and none out, to power a new three way switch?
jmbservices is offline   Reply With Quote
Old 09-16-2010, 07:40 AM   #2
Power
From what you describe, you can't, the power in the light box is always switched, no constant hot. You could get it from the outlet box.
The Following User Says Thank You to Just Bill For This Useful Post:
jmbservices (09-16-2010)
Old 09-16-2010, 07:46 AM   #3
Xtreme DIY'r
Power
Power can be run to the light 1st or the wall switch
No way of telling unless you take the face plate off & look
If there is only 1 cable at the switch then power was run to the light 1st
Outlet- unless controlled by a wall switch - will always have power
The Following User Says Thank You to Scuba_Dave For This Useful Post:
Old 09-16-2010, 08:14 AM   #4
Power
Is the three way switch setup for the same light or a different light?
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 09-16-2010, 08:51 PM   #5
Power
The power is for a different light that will be controlled by the 3 way switch.
Old 09-16-2010, 08:54 PM   #6
the Musigician
DangerMouse's Avatar
Power
Run it off the outlet....
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
The Following User Says Thank You to DangerMouse For This Useful Post:
Outdoor Hot Tub / Overhead Power line issue scottwilliamson Electrical 3 02-12-2010 11:37 AM
Devices to save on phantom power fetzer85 Electrical 7 12-04-2009 09:03 PM
Recurring Power Oddities - Regular Schedule DamienChaos Electrical 16 10-21-2009 08:45 PM
Amp meter Results - SE Cable Bad or Power CO jamiedolan Electrical 30 01-23-2009 01:16 AM
safe way to add extension to power cord sil Electrical 7 10-18-2007 10:58 PM
