Power A 240V Vacuum Cleaner - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-27-2013, 09:18 PM   #16
Rewards Points: 119
It is an universal motor, however diystephen has a point and I need to investigate further.
Alex
Metallo is offline   Reply With Quote
Old 03-07-2013, 07:58 PM   #17
Rewards Points: 119
Originally Posted by diystephen View Post
The frequency may not have an affect, but you would need to find the nameplate to be sure. The fact that NA uses two wires to get 240 can absolutely have an affect. Your appliance is wired to receive 240 on one blade (wire) and EU outlets are wired to only have one blade hot. What you are stating is to place 120 on the hot and neutral wires (to achieve a difference of 240.) This can have disasterous effects...
Hi,
I just wanted to confirm that a European appliance is wired to receive 240V on both blades, they are the same and can be plugged one sense or the other, As a result, wiring in the appliance can accept 240V on both hot or neutral.
Alex
Old 03-07-2013, 10:19 PM   #18
Idiot Emeritus
Rewards Points: 1,492
The only thing this motor cares about is that it sees 240 volts.
It doesn't matter if it's 240 & 0, 120 & 120, 200 & 40, or any other combination.
Rob
micromind is offline   Reply With Quote
Old 03-07-2013, 11:11 PM   #19
Rewards Points: 948
Why are go going though all this for a really old 240w vacuum? A decent vacuum is at least 1200w. Toss the silly thing.
Toller is offline   Reply With Quote
The Following User Says Thank You to Toller For This Useful Post:
joecaption (03-08-2013)
Dumb electrical question about potentially overloading a power socket zapp Electrical 2 02-18-2011 10:43 AM
Rainbow Vacuum cleaner repair pinkertonpv Appliances 1 12-02-2009 03:02 PM
No Power at Electronic Air Cleaner Junction Box edge10 HVAC 1 09-28-2009 08:26 PM
replacing switch on old fiter queen vacuum cleaner yummy mummy Appliances 1 05-05-2007 03:33 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 11:23 PM
