Power To 200 Amp Box With Generator - Electrical - DIY Chatroom Home Improvement Forum
Old 07-17-2012, 10:16 AM   #1
power to 200 amp box with generator
trying to feed 200 amp box from disconnect from generator. no power thru breakers why is this not working ?????
power to 200 amp box with generator-0716121617.jpg   power to 200 amp box with generator-0716121617a.jpg
crave is offline   Reply With Quote
Old 07-17-2012, 12:50 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
Want to try explaining a little better what you are doing?
What you wrote make no sense.
Where does the genny fit into all this? I see NO provisions for it.
Speedy Petey is online now   Reply With Quote
The Following User Says Thank You to Speedy Petey For This Useful Post:
frenchelectrican (07-17-2012)
Old 07-17-2012, 12:50 PM   #3
" Euro " electrician
frenchelectrican's Avatar
As far I can see there is couple issue that did come up real quick.,
A) you have wrong brandname breakers in your inside panel ( I counted at least 3 for sure )
Second thing where is the generator breaker is located ??
Third I rather have the generator breaker located outside. less thing can go wrong.
Merci,
Marc
A discussion on the Proper grounding for portable generators Stubbie Electrical 41 07-05-2012 10:15 PM
Generator power inlet box Bluewrx2001 Electrical 11 11-13-2011 06:16 AM
Recommend good power conditioner for running on generator power? Badfish740 Home Theater 0 11-04-2011 11:25 AM
B&S Generator with Connecticut Electric Xfer Switch Rick5150 Electrical 19 01-20-2011 10:14 PM
Honeywell mini zone and generator power daddyrabbit HVAC 2 02-12-2010 10:09 PM
