Potentially Dangerous Wiring In Old House - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-24-2012, 05:52 PM   #16
Originally Posted by ryanb22 View Post
Wtf? Under what circumstances would I feel a shock? I'm not sure what toure talking about.
Anyways, I was going to replace the receptacle with a GFCI receptacle, but I read that you shoudnt use a surge protector with them because they rely solely on ground.
If your ground wire voltage is caused by capacitors in surge protectors you will probably feel a shock if you touch this conductor and are grounded at the same time because the capacitors can supply enough current to shock, like in my oscilloscope example.
If your ground wire voltage is caused by a phantom voltage you probably will not feel a shock if you touch this conductor and are grounded at the same time because the capacitance that generates phantom voltages cannot supply much current, probably less than 1 mA.
After sandblasting: Is sand residue around exterior house dangerous? sings2strings General DIY Discussions 12 01-31-2012 09:44 AM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 02:40 PM
1939 House Wiring upgrade jimmyfloyd Electrical 4 10-01-2008 03:56 PM
Cost of replacing old knob ant tube wiring in house bikerboy337 Electrical 3 03-26-2005 08:50 AM
