Potential Breaker Sabotage - Need Your Input! - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-08-2011, 03:57 PM   #16
Rewards Points: 150
So is the monster power center damaged that everything was plugged into? I had an HTS3500 MK2 that would burn itself up at the slightest threat of high incoming voltage. Monster replaced it 2x before I sold it. Your powerbar would have been toast (unless it's not actually a surge protector) if your roomate blasted the circuit with high voltage.
My question here is; Are you sure you didn't get a big jolt of juice through an ethernet cable? I had a brownout scenario where the power went nuts during a T-storm and it cooked everything that was connected to my internet/ethernet setup. Is this a surge that could have rode in on your coax cable for internet/cable?
That would more likely explain the damage you have described.
240sx4u is offline   Reply With Quote
Old 02-08-2011, 04:01 PM   #17
fabrk8r
fabrk8r's Avatar
Originally Posted by jonlouis View Post
Whaa?
I've been using 2 of these: http://www.monstercable.com/productdisplay.asp?pin=4088
Quite pleased with them actually. On another note, about 2 months before my incident, 1 of the 2 got zapped, which I replaced immediately. What's weird is that when the "surge" incident occured, it didn't ruin either of the 2 bars.
Of the 9 reviews for this surge protector, it appears that at least 2 others had the same type of problem.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 02-08-2011, 04:36 PM   #18
That's a very good possibility. Another possibility is that the surge suppressor may not have been connected to a ground (either due an ungrounded outlet or faulty/old wiring). Without a functional ground, a surge suppressor essentially offers zero protection. If the OP was renting, there's no guarantee that the building wiring was sufficient to allow the suppressor to work, anyway.
The moral of the story is get insurance!
clashley is offline   Reply With Quote
Old 02-08-2011, 04:54 PM   #19
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 46
lol monster cable. They will gouge you just because they can. A $9 surge bar probably does the same as that one, but if your equipment is fried I'm wondering if it even is affective at all, assuming the surge came through power.
Is your internet/phone shared or do you have your own incoming line and is it protected? I would start to suspect that.
If you really think it was a sabotage, this may be one of many possible ways to do so:
http://www.fiftythree.org/etherkiller/
This is so old I think I was in high school the first time I saw that site, still very funny to go through
Red Squirrel is online now   Reply With Quote
Old 02-08-2011, 05:01 PM   #20
Rewards Points: 150
Red, that was hilarious!!!
20 amp GFCI breaker pops when pool pump is turned on. jagrunner Electrical 11 03-19-2010 05:31 PM
small voltage on circuit with breaker off jasonmechler Electrical 3 08-24-2009 09:52 AM
Need help, breaker unstable Atroxx Electrical 16 08-08-2009 11:53 AM
Tandem Breaker and Circuit(s) whowadat Electrical 1 01-09-2009 05:13 AM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 09:59 PM
