Potential 220 Outlet Issue, Can It Be Moved? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-23-2011, 03:00 PM   #1
Rewards Points: 337
potential 220 outlet issue, can it be moved?
So we are finishing a kitchen remodel, they had to shift my base and upper cabs 1/2" to the left to due to a out of plumb wall on the right, I have floor to ceiling cabs on two ends. I might be jumping the gun but I had the 220 outlet for our range at the correct spot I just measured again now that the cabs are in and it looks like I am 1/4" short as the cabs moved to the left. The mfg, has two open 7.5"x5" sections at the bottom rear of the range on each side for the 220 plug to recess under the range so it can be backed against the wall. Based on my measurements, I am not short by 1/4" and there is no wiggle room, the opening is exactly 30".
So, can the existing box be used as a junction box and we can cut a new box a few inches over and just put a cover plat over this one? Or can this 220 outlet be hard wired with conduit so I dont have to use the huge 220 cord?
titan7 is offline   Reply With Quote
Old 01-23-2011, 06:59 PM   #2
Electrician
Rewards Points: 794
As long as you can get into the old box and access the joints you are good.
How much wire did you leave in the old box, if you have enough maybe you could put an EMT nipple between the exisiting box and the new box and push the wires over to the new box without makeing any joints in the old box.
darren is offline   Reply With Quote
Old 01-23-2011, 07:58 PM   #3
I suspect that cutting the cord end off the range would violate the listing. And more importantly the warranty.
Andy-n-ATL is offline   Reply With Quote
Old 01-23-2011, 09:17 PM   #4
Maybe not. New ranges don't come with a cord.
Pistol Pete is offline   Reply With Quote
Old 01-23-2011, 09:36 PM   #5
Rewards Points: 337
thanks for the info, I did not move the 220 box during the remodel so its the OEM box with the 31 yr old house, there is no slack in the wires in the box. so I guess we would have to add a box on the other side of the stud and drill a hole into the double gang box the 220 outlet is now and somehow extend the line about 4-5 inches. Can this be done?
Can't the 220 range be hard wired with conduit so that huge plug will not hit the back of the range?
Old 01-23-2011, 10:33 PM   #6
Yea but probably so 'cause the op keeps mentioning the huge plug.
AndyinAtl is offline   Reply With Quote
Old 01-23-2011, 10:35 PM   #7
Titan,
The range has come with a plug. That means it should be plugged in.
Old 01-23-2011, 10:59 PM   #8
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Your new range should come with instructions on how to hard wire the range as an option to a cord and plug method. Many ranges come with a set of 3 lugs that you install on the terminals of the range wiring block so you can run a flexible metal conduit with individual wires inside from junction box the the range terminal block. Do not try to terminate the wires to the range screws , they are designed to take ring terminals or spade terminals only. Again read the instructions they should tell you what you need to know.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 01-24-2011, 11:30 AM   #9
Rewards Points: 337
Thanks for all the advice. I had the range delivered this morning as that's the only way to really know whether it will fit. I think I am okay now, with a 1/4" to spare based on taking the actual measurements of the range.
Here is the only Dumb A$$ thing I did. I whated to measure how far the 220 cord plug will be off the wall and and towards the side edge of the range. I thought I will will just plug it in and take the measurements, well, appearently the electrican left the 220 circuit live (the rest of the kitchen is off at the panel).
When I plugged the cord in I got a arc as the the 3 wires on the other end hit each other at the other end of the plug. I quickly realized there was power at the outlet, stupid, stupid, stupid, I should have checked the panel myself but I assumed everything was still off as there are no outlet hooked up. I did check the panel and this arc did not trip the 220 circuit breaker??
I am just kicking myself, I am glad I was not touching the leads on the end of the cord. Stupid, stupid, stupid.
Old 01-24-2011, 02:36 PM   #10
So I assume the receptacle hadn't yet been installed? A nice vigorous arc can indeed be an exciting thing.
Glad you are ok. Always assume stuff is hot.
Old 01-24-2011, 02:47 PM   #11
Rewards Points: 337
The 220 outlet is in the wall. I completely forgot there were three bare wires at the other end of the 220 flexible cord that would attach to the range. When they hit the concrete and touched there was a nice flash that scared the heck out of me. I have been sick to my stomach over this, just too stupid, a moment of not thinking
So, here is the question, it does not look like the breaker tripped? That's sort of scary? Shouldn't it have tripped on a short like what I did? Perhaps it's a bad breaker?
Old 01-24-2011, 07:51 PM   #12
Semi-Pro Electro-Geek
Rewards Points: 2,944
Presumably this was a very brief short, lasting no more than a fraction of a second. It's entirely possible that the fault current was just not high enough for long enough to trip the breaker, even if it's functioning normally. However, I too would be concerned about the lack of a trip in that circumstance. What brand and age is the panel? Does the breaker handle operate normally? Does it look or feel damaged or unusual?
mpoulton is offline   Reply With Quote
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 03:36 PM
Potential Ground Fault issue? Diagnosis? revnine Electrical 12 03-27-2010 07:48 PM
Outside: Adding an outlet to a switched light fixture indigo Electrical 9 12-15-2009 09:48 AM
Exterior 50 Amp RV Outlet theatretch85 Electrical 9 11-04-2009 11:07 PM
I moved an electrical outlet. luweee Electrical 2 06-08-2009 08:20 AM
