Pot Lights Wiring Diagram - Electrical - DIY Chatroom Home Improvement Forum
Old 03-28-2010, 04:11 PM   #1
Pot lights wiring diagram
Hi, I'm trying to figure out what wiring connection I have to make for 6 pot lights to be controlled by dimmer, can I use parallel wiring connection or a series wiring connection, pls. help.
Mat
Eaglenest is offline   Reply With Quote
Old 03-28-2010, 07:47 PM   #2
Electrician
Rewards Points: 770
To keep it easy you run the feed to the switch and then come out of the switch to your first light and daisy chain the rest. This will put your lights into parellel.
darren is online now   Reply With Quote
The Following User Says Thank You to darren For This Useful Post:
Eaglenest (04-03-2010)
Old 03-28-2010, 08:46 PM   #3
Rewards Points: 81
If you put them in series they will be dim. They need to be in parallel.
Chevyman30571 is offline   Reply With Quote
The Following User Says Thank You to Chevyman30571 For This Useful Post:
Old 03-29-2010, 11:20 AM   #4
Rewards Points: 131
If you do decide to add more than 6 cans, make sure your dimmer can handle the wattage. Cheaper dimmers max around 600 which is perfectly fine for 6 cans.
HitLines is offline   Reply With Quote
The Following User Says Thank You to HitLines For This Useful Post:
Old 03-29-2010, 12:21 PM   #5
Dimmer capacity is by load...not number of lights
With CFL's or LED bulbs you could control quite a few
But limiting a 600w dimmer to 6 cans is a good idea if they can take a 100w bulb
Even with 75w bulbs 6 cans is near the limit for a 600w dimmer
In one room I split 9 cans between 2 dimmers & a switch for more control of the light
The Following User Says Thank You to Scuba_Dave For This Useful Post:
Old 03-29-2010, 01:09 PM   #6
Rewards Points: 131
Right you are about the load not the number. If you put in 75watt bulbs you could go as high as 8 in theory but that is pushing the max.
That has generally been my experience. Dimmable CFL bulbs are still crazy expensive so I was assuming 1 can @ 100 watts.
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 08:53 AM
Recessed lights, wiring, breaker buzzing, etc diyguy999 Electrical 3 12-21-2009 02:10 PM
Changing switch for lights in basement, confused on current wiring. RyanD Electrical 2 05-14-2009 09:37 PM
Wiring diagram for lights with two switches Ed M Electrical 7 08-10-2008 09:59 AM
Wiring diagram, would this work firemanpato Electrical 10 01-07-2008 05:33 PM
