Pot Lights... HELP !!! - Electrical - DIY Chatroom Home Improvement Forum
Old 04-05-2011, 08:36 AM   #1
Pot lights... HELP !!!
Ok ... quick question
I have a living room....12'2"Wx13'6"L....... I have SIX- 50W Par20 pot lights.
How should they be placed around the room... ?? @ one end, I have a entertainment unit I am building in the wall . The other end a couch.
Currently.... we have spaced them 4' apart right now, but they are WAY to close together.
I plan on going 2ft from the out side walls around the parimeter ?
Yes/ no ??
Thanks for any input !!!
tyhatts is offline   Reply With Quote
Old 04-05-2011, 09:38 AM   #2
I=E/R
a7ecorsair's Avatar
How high is the ceiling? Will you be using flood lamps for even distribution or will you be using spot lamps for focused lighting?
a7ecorsair is offline   Reply With Quote
Old 04-05-2011, 11:59 AM   #3
8ft ceilings, and they will be used for the main lighting in the room, I have them on a dimmer switch.
The wall between the livingroom and dining room/kitchen has been knocked out to make a 9 ft opening .... Also, we replaced the 4ft window on the outside wall, with a 6 ft window( 6'x4.5' ).
Finding underground electric wire for driveway lights. mitch21131 Electrical 25 09-24-2012 09:52 AM
Use factory fog light switch for aftermarket lights? downunder Automotive Repairs 6 07-10-2010 12:45 PM
Changing switch for lights in basement, confused on current wiring. RyanD Electrical 2 05-14-2009 09:37 PM
New lights in basement CooperChloe Electrical 11 01-11-2009 12:22 PM
Adding can lights to an existing circuit TexasEd Electrical 1 06-17-2008 08:23 PM
