-   -   Pot lights... HELP !!! (http://www.diychatroom.com/f18/pot-lights-help-100594/)
tyhatts 04-05-2011 07:36 AM
Ok ... quick question
I have a living room....12'2"Wx13'6"L....... I have SIX- 50W Par20 pot lights.
How should they be placed around the room... ?? @ one end, I have a entertainment unit I am building in the wall . The other end a couch.
Currently.... we have spaced them 4' apart right now, but they are WAY to close together.
I plan on going 2ft from the out side walls around the parimeter ?
Yes/ no ??
Thanks for any input !!!
a7ecorsair 04-05-2011 08:38 AM
How high is the ceiling? Will you be using flood lamps for even distribution or will you be using spot lamps for focused lighting?
tyhatts 04-05-2011 10:59 AM
8ft ceilings, and they will be used for the main lighting in the room, I have them on a dimmer switch.
The wall between the livingroom and dining room/kitchen has been knocked out to make a 9 ft opening .... Also, we replaced the 4ft window on the outside wall, with a 6 ft window( 6'x4.5' ).
