Old 03-14-2008, 05:32 PM   #1
Default Pot lights in a drop ceiling
Ok, phase one of my basement reno project went well - planning. I now have the boxes installed, and tahnks to some good folks here, I have now finalized my wiring diagrams.
So, I arrive home with all of the supplies needed, start installation of the electrical boxes, complete that part, ready to locate and put up the lighting. Small lights - easy - install metal box to host the wiring, the eventually the ceramic light will attach. These are in rooms with no drop ceiling - so no issue. Go to the main room where there will eventually be a drop ceiling, and oh oh???????
Well - what can I say - I have never worked with pot lights before. I have never worked with a drop ceiling before. I figure that pre planning is best unless I want a real mess later to fix. So my questions to help me prevent a real mess are as follows:
1) My pots (or Cans) have bars on them that are meant to be supported by the joists up above. Of course, because I am using a drop ceiling, this is not possible. How should I install them in the drop ceiling - can i mount the supports on the pots to the drop ceiling frame? is that safe? Should I wire them to the joist above instead, or in combination with mounting them to the ceiling frame?
2) I am doing all of the wiring now, and then will be doing the drywall, with the drop ceiling going in last. What do I do with these lights between now and then - do I install them in the ceiling joists - and move them down later, do I hang them temporarily with wire from the ceiling joists, do I just put junction boxes up where the lights eventually will be?
3) No matter how I do it now, I will need excess wire left to be able to lower the lights once the project is done. I once had an issue with the electricion that inspected my work when I left too much excess wire outside the lighting and outlet boxes. Is it safe to leave some excess wire for a short period of time until the project is completed so that I can lower the lights into the drop ceiling later on?
4) Another thought, should I set up separate boxes from the built in ones contained in the cans up in the ceiling, and use them to join up the boxes at a future date? By doing this I can put regular ceramic lights up until such time I am ready to install the pots. If I do this, is it ok later remove the ceramic light, join the pots into these boxes and cap the old box up in the drop ceiling, or does the box need to be lowered to the level of the drop ceiling as well with a plate providing access? I read somewhere that any junction boxes cannot be buried in a wall or ceiling?
ugh - so many questions on one lil issue - and this project was moving along so well.
Thx for any help
Howdy
Howdy is offline   Reply With Quote
Old 03-14-2008, 06:14 PM   #2
The brackets have notches in them to fit into the ceiling grid. Lay the can lights on top of the grid. Line up the notches up so they sit on the grid, then you can either use screws or tie wire to secure it to the grid.
As for the wiring I would mount a j box in the in the middle of three or four lights. Leave whips long enough to hit the three or four lights. Make up the j box, cover it. coil up and cap off the wires. This way when you get the grid in all you have to do is hook up the light. The hardest part is cutting those dam ceiling tiles for the cans.
I wouldn't temp mount them, just seems like more trouble than its worth. If you need light just go get a couple task lights
bwinters12 is offline   Reply With Quote
Old 03-14-2008, 09:55 PM   #3
wfischer's Avatar
You know, from the title of this thread, I thought for a second that you were trying to install some special sort of lighting to aid you in growing an illegal substance.
But that's just me.
wfischer is offline   Reply With Quote
Old 03-14-2008, 10:23 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
What brand of cans are they?
1) Cut out the tiles for the lights and place them in position. Leave out at least one tile next to each light.
2) Provided there is enough room to work around the lights, place each light in it's position and secure to the grid.
3) Wire from light to light working from the open tile. I see NO need to use the "spider" method of using a j-box and running out from there. To me this seems like unnecessary work.
4) Install the trims, lamps, and remaining tiles.
Old sig removed. Thankfully Advanta is dead.
More On This Topic
Hi, this is Jon and in this clip we will be installing our fixture box. Now, with the can light that we pulled out, the diameter is about six inches. However, the diameter for our mounting plate is only about four inches. Now, because our opening is so... Read More »
If you are at a loss as to what to do with your keepsakes, handed down furniture, year books, children’s toys or holiday ornaments, you should look up and consider your attic. Homes used to be made with stairs that went to the attic. Here children... Read More »
Hi! I'm Chad Smith and I'm a State Certified Journeyman wireman; basically an electrician. I'm here today with expertvillage.com and we are hanging a ceiling fan in this house. Now we've already been through all the steps of shutting the power off... Read More »
Hi, this is Jon on behalf of Expert Village. In this video clip we will be removing our old light fixture. On our old light fixture we're going to start by removing the nut in the center of the plate. Once that has been removed our plate should pop off... Read More »
Hi! My name is Adolph Ramirez from Tampa, Florida on behalf of Expert Village, this is how to install a ceiling fan. Again, you've got to make sure that the box is installed properly. Make sure that it is on a wooden support or a metal bracket up above... Read More »
Drop ceiling...what is the minimum drop? gone_fishing Remodeling 2 02-25-2008 12:13 AM
Installing can lights in a drop ceiling..... rwk0930 Remodeling 1 02-19-2008 02:59 PM
How to convert a drop rod ceiling fan to ceiling mount? Bacardi 151 Electrical 5 01-13-2008 10:04 PM
Work lights in basement with drop ceiling fw2007 Electrical 2 10-20-2007 11:39 AM
changing drop ceiling to normal ceiling acoustic_bum General Discussion 7 01-16-2007 09:52 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
