Pot Lights In Bed Room Pictures - Electrical - DIY Chatroom Home Improvement Forum
Old 01-02-2012, 02:44 PM   #1
Pot lights in bed room Pictures
I'll be re instillation my attic this year and was wondering on how can I prevent the wind from going through them. Am I able to put installation over them or some type of cover for them?
Change of the subject for a second too:
My attic ladder in the hall way, how can I stop the wind from coming through that too.
[IMG][/IMG]
[/IMG]
NEMO-DYIER is offline   Reply With Quote
Old 01-02-2012, 02:51 PM   #2
Rewards Points: 6,652
First thing I would do, is straighten out that rats nest of romex. Then I would use DAP foam in the can to seal around the edge of the can and the roof, but do not do it, until you get a shop-vac up there to clean up all the dirt and dust around them. They make roxwool covers that go over the cans also. Also make sure that you foam or caulk around all places that piping and wiring enters the attic space, then after that, get it the space insulated.
Let me guess though, right now when it snows if you are in the snow belt, your house along with a few others have no sign of snow on the roof whatsoever.
Old 01-02-2012, 03:00 PM   #3
Thanks for the help will check it out about the covers.
I know about the dust and crap up there. Just had my roof done this year.
And about the snow YES I do have snow on my roof. Im not loosen any heat from the lights. It's just on cold windy days I can feel the wind come rite through them.
Old 01-02-2012, 06:18 PM   #4
Master Electrician
Rewards Points: 3,750
[IMG][/IMG]
[/IMG]
That looks like a non-IC can to me. Keep insulation at least 3" away from it.
brric is online now   Reply With Quote
Old 01-02-2012, 06:51 PM   #5
biggles's Avatar
on that attic ceiling stairs drafting cut out a piece of 3/4 plywood to fit into the opening it will be a PITA to lift going up the stairs when going up for the winter but it's worth it
Old 01-02-2012, 07:33 PM   #6
Mad Scientist
Also, the clamp where the two cables enter the light is missing the piece that makes it a clamp. That should be replaced.
McSteve is offline   Reply With Quote
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 04:34 PM
One room cold- what pipes are what...help cciampi HVAC 24 02-20-2011 12:44 PM
removing roof supports in attic, installing a room denemante Building & Construction 4 01-24-2011 09:51 PM
On bloody HOT room. rahlquist HVAC 30 04-20-2009 08:50 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
