Pot Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 02-10-2013, 08:47 PM   #1
listo's Avatar
Rewards Points: 93
Pot lights
Do you need a junction box or do they wire in directly?
listo is offline   Reply With Quote
Old 02-10-2013, 08:51 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 140
Can lights have a built-in j-box.
The Following User Says Thank You to jbfan For This Useful Post:
listo (02-20-2013)
Old 02-10-2013, 08:55 PM   #3
MarginallyQualified
Rewards Points: 2,464
Recessed lights include a junction box on them.
The Following User Says Thank You to TarheelTerp For This Useful Post:
listo (02-20-2013)
Old 02-10-2013, 09:28 PM   #4
" Euro " electrician
frenchelectrican's Avatar
99% of the recessed can do have junction box to hook up your cable or conduit.
The only kind I will try to advoid is the cheap knock off recessed can which they have a junction box top of the recessed cans (that is pretty much the worst design I have see due the heat will useally destory them pretty fast )
Merci,
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
listo (02-20-2013)
Old 02-10-2013, 09:39 PM   #5
listo's Avatar
Rewards Points: 93
Thank you et merci beaucoup everyone
Trouble with GFCI Outlet + Switch for pool lights kentf Electrical 5 05-23-2011 12:37 PM
Problem: Puck lights w/ touch-sensitive switch mapsedge Electrical 1 03-14-2011 08:20 AM
Low Voltage Exterior Stair Lights Jupe Blue Electrical 2 02-16-2011 07:28 AM
Adding can lights to an existing circuit TexasEd Electrical 1 06-17-2008 08:23 PM
Added can lights, tripping GFI tandyt Electrical 3 05-18-2008 10:55 AM
