Pot Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 01-03-2012, 09:09 PM   #1
Pot Lights
In 50 watt pot light fixture how many wires can go I mean if there is one hot wire can I take 2 more wires to give connected two more pot light.In other farm if i have pot light 1 , 2 and 3 . I put the hot wire in no 2 and from there I take one wire to no 1 & one wire to no 3 .please clear me a bit
saeed M is offline   Reply With Quote
Old 01-03-2012, 09:25 PM   #2
Licensed electrician
Rewards Points: 1,872
The junction box should tell you how many cable or conductors are allowed in them.
Old 01-03-2012, 09:29 PM   #3
MarginallyQualified
Rewards Points: 2,464
Originally Posted by saeed M View Post
In 50 watt pot light fixture how many wires can go...
If you mean how many can fit within the connection box...
that is referred to as "box fill" and the answer will vary by maker.
But most will hold more than should ever need to be connected.
...if there is one hot wire can I take 2 more wires to give connected two more pot light.
That would be a total of 3 sets of 2W (romex?) = 6 plus 3 ground wires.
And yeah... they'll fit in most if you're careful.
A better way would be to run the wire around the room:
---> Light ---> Light ---> Light ---> Light ---> (etc)
This way you never have more than 2 sets of wire per light.
hth
Old 01-04-2012, 12:21 AM   #4
Julius793's Avatar
hth
That's what I used to think!
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-04-2012, 02:08 AM   #5
Not a Noob or Boob
hth
What he said!
Rob1975 is offline   Reply With Quote
Finding underground electric wire for driveway lights. mitch21131 Electrical 25 09-24-2012 08:52 AM
Need info on replacing 8 recessed lights in bathroom OhmZoned Electrical 1 11-07-2011 12:35 PM
Use factory fog light switch for aftermarket lights? downunder Automotive Repairs 6 07-10-2010 11:45 AM
Changing switch for lights in basement, confused on current wiring. RyanD Electrical 2 05-14-2009 08:37 PM
Adding can lights to an existing circuit TexasEd Electrical 1 06-17-2008 07:23 PM
