POT Light In Return Air Duct Jst. Bay?? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-30-2009, 09:21 AM   #1
Question
POT light in Return Air Duct Jst. Bay??
Hi.
In my basement I have TJI wood joists. Between a pair of them I have a Return air duct (basically just metal screwed to the U/S of the joist to keep it closed). I need to have a Pot light in between the joists due to my layout but the R/A duct is there.
Is putting a Pot light in a Return Air allowed? I don't see why not considering its not the HOT supply air but I don't know the code very well.
I live in Manitoba Canada if that helps.
Matt
mfleming is offline   Reply With Quote
Old 04-30-2009, 09:33 AM   #2
Ok, so I found you need to use special NMD90 plenium wire and can only run in THROUGH the duct and not along side it. So having a light up there would never work.
What about if I built a wood box inside the joist bay with 1/2" drywall on the inside then place the Pot light inside this? I should still have enough airflow around the box for my return air plus I have a sealed fire guard box for the light.
What do u guys think?
Old 05-01-2009, 07:23 AM   #3
Rewards Points: 1,492
Why could you not have a junction box in the next stud bay where the regular wire runs, and plenum rated wire in perhaps two feet of metal flex conduit going through the joist to the can light on the other side? (Do they make plenum rated non-metallic (NM) sheathed cable so you would not need conduit?)
If you built the wood enclosure with enough ventilation space inside for the can light itself, are you sure there would be enough remaining cross sectional area in the bay for the return air?
Old 05-02-2009, 01:54 AM   #4
DIYer
I'm pretty sure there's no plenum rated NM... you have to go with plenum rated MC.
Gigs is offline   Reply With Quote
question on return duct familyman HVAC 13 01-25-2009 11:05 AM
Does return duct width matter? bvbellomo HVAC 13 01-11-2009 02:03 PM
Return duct "boot or no boot" ads67 HVAC 16 01-10-2009 09:38 AM
Water in (and around) return duct kennelm HVAC 6 06-18-2008 06:13 AM
