Pot Light Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 12-19-2010, 08:36 PM   #1
Pot Light Problem
I have 6 halogen pot lights on a dimmer in my basement, all wired on the same circuit.
One stopped working today and once I replaced it, now all either dimly flicker when I turn the lights on or don't turn on at all.
Any ideas?
Avery is offline   Reply With Quote
Old 12-19-2010, 10:15 PM   #2
Rewards Points: 1,548
You may have miswired the new light into the circuit, producing a "series circuit" where current has to flow through two lights in sequence. This causes the affected lights to each get far less than 120 volts.
Old 12-20-2010, 06:55 AM   #3
If that was the first light in the chain, it could be a loose connection.
Old 12-20-2010, 07:16 AM   #4
the Musigician
DangerMouse's Avatar
Loose connection or possibly the new bulb did not go in correctly?
DM
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
Don't understand this breaker tripping problem majesticjess Electrical 10 03-05-2010 06:42 PM
light fixture removal problem rpavlick Electrical 5 11-19-2009 04:40 PM
Another motion sensing light problem Steelhead Electrical 6 12-24-2008 09:50 AM
Weird Problem with new light.... MRTOWNDRO Electrical 8 12-21-2008 04:00 PM
