Old 05-04-2008, 12:11 AM   #1
Post
pot light holes
I have to drill holes in plaster for pot lights . My drill bit 5 1/2 inch keeps wearing out and they are expensive . Any suggestions ?
justboating is offline   Reply With Quote
Old 05-04-2008, 08:19 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
pot light holes
A Rotozip with a carbide bit. Then change to a "Saber" (wood) bit for the wood lathe.
Plaster and lathe will kill anything not carbide in short order.
Old 05-04-2008, 08:23 AM   #3
pot light holes
For plaster I can't think of a better way then this.
Cajun1 is offline   Reply With Quote
Old 05-04-2008, 09:24 AM   #4
Power Gen/RS Engineer
pot light holes
When you say 5-1/2", I'm assuming that this is a hole saw? If so, I know what you mean as to the price. I had to cut 22-4" holes in my second floor ceiling which is also plaster and lath. My hole saw made it all the way through the job alas it was about as sharp as a bowl of oatmeal when I was done. After the fact, 220/221 indicated in an earlier thread (see below) that you could run the saw reverse through the plaster layer and then switch to forward to cut the wooden lath. Evidently, this would preserve the teeth since cutting the plaster layer is what's killing them.
I haven't tried it myself but go ahead and report back!
Also, look at entry #24, page two of the following thread (earlier on this site):
Hole saw advice for ceiling boxes
I devised a contraption to catch all of the plaster dust. PM me if you'd like a picture or more information. Also, a lot of discussion throughout about the subject of hole saws, etc.
Jimmy
The very existence of flamethrowers proves that some time, somewhere, someone said to themselves,"You know, I want to set those people over there on fire, but I'm just not close enough to get the job done." - George Carlin
BigJimmy is offline   Reply With Quote
Tags
drill holes, electrician, plaster, pot lights
Whirlpool Microwave light issue mustangcobra44 Appliances 8 08-14-2008 04:52 PM
Need to replace can light with standard light Woodcutter Electrical 3 02-29-2008 08:06 AM
Hall light worked before installing a new light fixture in bathroom jcfan7 Electrical 40 02-23-2008 10:46 AM
Trying to replace wall mounted light fixture jtm2300 Electrical 4 08-03-2007 10:44 PM
Hot Light Outlets Materials Guru Electrical 5 07-31-2006 08:11 PM
