Pot Light Failure - Electrical - DIY Chatroom Home Improvement Forum
Old 01-13-2011, 04:08 PM   #1
Pot light failure
Three of four lamps work. There appears to be 12 volts to the failed lamp. Is it possible that the thermal protector for this lamp is broken?
19471947 is offline   Reply With Quote
Old 01-13-2011, 04:40 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 138
How did you measure the voltage?
If the thermal was bad, you would not read a voltage.
Old 01-13-2011, 06:09 PM   #3
I used a multi meter across the wires to the lamp holder
Old 01-13-2011, 07:48 PM   #4
Journeyman Wireman
Rewards Points: 150
Are they low voltage lights? Do you have the correct lamp? Are the lamps making good contact? If you wiggle the lamp in the holder do they come on? In some low voltage lighting, the lamp holders wear and and the lamp don't
make good contact.
If it is low voltage lighting, then it also possible that that transformer has gone bad.
Any of the above can be fixed and or replaced.
Jupe Blue is offline   Reply With Quote
Old 01-13-2011, 08:16 PM   #5
Appear to be low voltage. Checked the functioning lamps from other sockets in the bad socket, and they do not work.
Tried a new lamp holder and checked it with a bulb in a good socket OK. When tried in the bad socket nothing.
Is it possible that the transformer could fail only one of the four?
Old 01-14-2011, 01:22 AM   #6
Journeyman Wireman
Rewards Points: 150
It probable that each light has it's own transformer and it could fail. Are they new work or remodel can lights? You should be able to remove the can housing and pull out the transformer for replacement.
Old 01-14-2011, 06:33 AM   #7
There were a remodel several years ago. I was able to remove the pot from the defective lamp and there is nothing attached to it other than connecting wires.
Old 01-14-2011, 06:35 PM   #8
For some unknown reason the defective fixture now works. The famous "loose wire?"
Old 01-14-2011, 07:03 PM   #9
Rewards Points: 1,418
Were you able to see exactly how the wires entered the fixture and are connected to the socket? The loose connection could even be a corroded rivet that held the wire on or held two pieces of metal together.
Help wiring ceiling light wylde8 Electrical 1 09-24-2009 07:29 AM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 08:52 PM
Grout question poolecw Flooring 11 10-29-2008 08:32 PM
Marmoleum repairs muggyfrost Flooring 8 10-16-2008 09:19 PM
