Post Lamp Power - Electrical - DIY Chatroom Home Improvement Forum
Old 12-22-2011, 02:16 PM   #1
NAIL BENDER's Avatar
Question
Post lamp power
I want to run power to four post lamps, the furthest of which is about 150ft from the breaker. I planned on using UFB-14/2 through PVC conduit and I found a 'Conduit Fill Chart', but it makes my last two functioning braincells hurt.
Question is: How large PVC do I need and with the first pull being at least 75ft, is this an impossible task...?
Thanks for sharing your wisdom.
Danny aka: NAIL BENDER
NAIL BENDER is offline   Reply With Quote
Old 12-22-2011, 02:53 PM   #2
Mad Scientist
You don't need conduit if you use UF cable, except possibly to protect it where it comes up out of the ground.
McSteve is offline   Reply With Quote
The Following User Says Thank You to McSteve For This Useful Post:
plummen (12-22-2011)
Old 12-22-2011, 03:29 PM   #3
joed's Avatar
Rewards Points: 12,012
Is it a straight run or are there bends in it? How many bends?
Old 12-22-2011, 03:45 PM   #4
It will be straight runs, from breaker and post to post, so is using PVC for protection like wearing a helmet while on a motorcycle or while sitting in the Lazy-Boy watching TV...
Thanks for the help.
Last edited by NAIL BENDER; 12-22-2011 at 03:51 PM. Reason: Can't spill or spell...?
Old 12-22-2011, 03:59 PM   #5
Mad Scientist
Nothing wrong with doing it that way, in fact I hate direct-buried UF cable. It's somewhat failure prone and requires re-trenching to replace.
You'll definitely have an easier and probably cheaper job of it if you just run individual THWN conductors in the conduit, though. You could get by with 1/2" PVC.
If you do use the UF in conduit, I'd use 1". I think it'd be legal in 3/4", maybe even in 1/2", but it'll be much easier to pull in 1". UF is pretty stiff.
Like you, I'm having a hard time coming up with reasonable conduit fill numbers for UF.
Old 12-22-2011, 04:12 PM   #6
Thanks McSteve, nice to know the chart thing isn't just me....
Buring wire just doesn't feel right to me, so thanks for confirming that.
I've been on this site for only a couple of days and it has served me well. You guys are great.
Thanks again.
Old 12-22-2011, 04:31 PM   #7
Rewards Points: 1,574
I think you'll have a real hard time pulling uf through that much conduit. I'd go with the thwn if it were me.
bob22 is offline   Reply With Quote
Old 12-22-2011, 04:51 PM   #8
Missouri Bound's Avatar
If you use conduit...are you stubbing up into each pole? How were you planning to connect them...loop from one to the next?
Old 12-22-2011, 05:23 PM   #9
Yes Sir,
These lamp post are go'na be here at the ranch and will be made from surplus 'Drill Pipe', an endless commodity here in Texas. I figured I'd attach a small junction box at the base of each and connect the wires leading to the next lamp there. Should I post some photos when I get em done...?
Old 12-22-2011, 05:32 PM   #10
You can, but that answered my question. As long as you have JB, they are your pull boxes. You shouldn't have too much trouble pulling the runs. I'd use 3/4'" and pull individual wires. You will lose a bit of voltage at 100', but nothing significant for a lighting load.
Old 12-22-2011, 07:26 PM   #11
Good deal, 3/4 inch sounds like a trip to Home Depot.... Thanks
Old 12-22-2011, 08:26 PM   #12
If you already have the 1/2" use it. The 3/4" is NOT a necessity for THWN. But you will have to pull 4 wires.
Old 12-22-2011, 08:48 PM   #13
I haven't bought any supplies yet, so this information will help me avoid the Refund Desk at Home Depot.
Thanks.
Old 12-22-2011, 09:20 PM   #14
Mad Scientist
You sure? If these lamp posts are all going on the same circuit, he should just need a hot, neutral, and ground, yeah?
Old 12-22-2011, 09:34 PM   #15
Yeah, you are right...I'm experiencing yet another brain fart.....
Deck Post Height for Composite Post Railing ylwdog Building & Construction 5 11-15-2010 10:01 AM
old lamp post rewire tiso2010 Electrical 1 08-08-2010 06:59 PM
Wiring post outlet and lamp for light post Gordon Electrical 3 09-22-2008 03:39 PM
Electric receptacle in lamp post and flood light not working th31 Electrical 7 12-13-2007 08:46 AM
