Possible Way To Reduce Energy Cost??? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-25-2012, 07:55 AM   #1
Possible way to reduce energy cost???
Hi, I hope someone can let me know about a fairly new product that I saw on a local news network here in Atlanta. It's received coverage on TV as well as some of the local DIY radio shows here. The product is called Energy Crusher which is supposed to reduce your energy consumption by a guaranteed 8%, but could easily save anywhere from 10% - 20%. If that's true, the $329 unit would pay for itself in one year for most homeowners.
I'm including two links here...
one is a youtube demonstration... http://www.youtube.com/watch?v=tPdOy...eature=related
Company site... http://energycrusher.com/index.php/products/
My question to this forum is does this product make sense? I had an electrician from a local company come out to my house last night to demonstrate it. The unit is basically a large capacitor that stores unused energy and on a cycle of every 20 secs, gives that energy back to your electrical system through your neutral bar. (I'm not quite sure I understand it all).
Anyway the electrician said I would need to purchase two units because I have two 'legs' coming into my house's electrical panel. Does that make sense? If I understand him correctly that would mean some of my breakers are fed off of one line coming in and the other breakers are fed off of another line. I think this unit could be helpful, just trying to justify the cost for two units.
Thanks in advance for any comments!
twobyfour2 is offline   Reply With Quote
Old 02-25-2012, 08:09 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
Snail oil
er: I meant snake oil
Coastal South Carolina
Old 02-25-2012, 08:17 AM   #3
Banned Electrician
HARRY304E's Avatar
Rewards Points: 204
Smoke and mirrors.
Don't waste your money..
"Government is not the solution to our problem; Government is the problem."
HARRY304E is offline   Reply With Quote
Old 02-25-2012, 08:23 AM   #4
Rewards Points: 1,512
It's probably one of those devices referred to generically as power factor correctors.
However power factor issues are small or non-existent in homes. (Power factor inefficiency can be a problem in industrial settings where there is a lot of motorized tools and equipment. The poorer the power factor, the more kilowatts are supplied by the source to perform the same work.)
It so happens that connecting a capacitor from hot to neutral or from hot to hot (depending on the motor) will cut the overall power draw while the motor behaves the same way performing the same work
Yes you can overcorrect in which case the overall efficiency goes down. If you are not using electricity (the motor is turned off), the capacitors in a power factor correction device left connected will consume power, doing nothing useful.
Pure resistance such as for incandescent lights or baseboard heaters does not have power factor error.
Power factor can be explained using a sailboat as a metaphor. When the wind is behind you you get maximum power with the wind hitting the sail stuck out to the side straight on. The "power factor" is close to 100%.
When you want to sail in a direction other than the wind, you have to set the sail with the wind blowing at a diagonal. You don't go as fast for a given wind speed.
("Correcting the power factor" in sailing would consist of somehow redirecting the wind, which is impossible. You are just fortunate you can move at all; by zig zagging you can eventually get to a destination upwind.)
The Following User Says Thank You to AllanJ For This Useful Post:
darren (02-25-2012)
Old 02-25-2012, 08:23 AM   #5
Rewards Points: 160
Anything "supplied" to the neutral bar is wasted. The neutral and ground bar are bonded in the panel, so anything that ends up in the neutral or ground bar is dissipated into the earth. The power company could care less what you do with the power, after it passes the meter.
Besides, you have one phase coming into the house. The wire is split, 120v each, but there's not multiple phases. It all sounds like a scam.
matt151617 is offline   Reply With Quote
Old 02-25-2012, 09:00 AM   #6
Licensed electrician
Rewards Points: 1,598
The power returned to the neutral buss is not going into the earth. It wants to return to it's source, the transformer.
The Following 2 Users Say Thank You to Jim Port For This Useful Post:
mpoulton (02-25-2012), SD515 (02-25-2012)
Old 02-25-2012, 12:38 PM   #7
Semi-Pro Electro-Geek
Rewards Points: 2,938
Er, interesting analogy but not quite right on the sailing. Sailboats can go faster than the wind, and they can only do it when sailing across the wind. The more perpendicular the boat's course is to the wind, the faster it's theoretical maximum speed. In practice there is a limit determined by the sail's efficiency and the boat's drag in the water. http://en.wikipedia.org/wiki/Sailing..._than_the_wind
On the power factor stuff, of course, you're right. And power factor correction doesn't help your power bill unless you're in an industrial setting where the POCO monitors the power factor and charges a penalty for it. Residential meters charge for kilowatt-hours not KVA-hours, so the inefficiency of low power factor is paid for by the POCO not the customer.
mpoulton is offline   Reply With Quote
Old 02-25-2012, 01:42 PM   #8
You save money by using less electricity.
Turn things off. Buy "Energy Star" appliances. More, search google.com for the words...
Energy Saving Tips
Billy_Bob is offline   Reply With Quote
Old 02-25-2012, 01:55 PM   #9
long island, NY
you also can save a ton of electricity by unplugging appliances. a lot of appliances continually use some basal level of energy merely by being plugged in... not only things with lights and clocks like microwaves, but also suprisingly blenders, food processors, radios, TVs, the charging cord for your cellphone...
The biggest power hogs are those cable boxes. Even when "off" they're burning tons of energy.
the more you habitually unplug, the more the savings.
diy'er on LI is offline   Reply With Quote
Old 02-25-2012, 02:08 PM   #10
Electrical Contractor
jbfan's Avatar
Rewards Points: 464
Gotta love the Mr. Sparky ad.
They say savings up to 25%
Like others have said, snake oil.
Old 02-25-2012, 03:18 PM   #11
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Looks like something that you would see get promoted on one of those stupid infomercials in the middle of the night when you can't sleep and you are trying to find something to watch on TV.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 02-25-2012, 04:05 PM   #12
Energy Crusher
The Energy Crusher work very well i have had it in my home in New Jersey for the past 13 months each month shows a reduction of KWATTS used The same people who dont think it works are the same people who 30 years ago thought a TANK LESS HOT WATER HEATER WOULDNT WORK EITHER THEY WOULD SAY HOW CAN THIS LITTLE HEATER OF HOT WATER HEAT OUR ENTIRE HOME WELL IT DOES
bcohenc is offline   Reply With Quote
Old 02-25-2012, 04:06 PM   #13
Old 02-25-2012, 04:17 PM   #14
liscenced electrician
Rewards Points: 538
I've never heard a single electrician (that wasn't selling them) say anything good about power factor correctors in a residential application. Motor loads in a house are minor. Heat and ac are what drive up your electrical bill and neither are effected by powrr correction
jimmy21 is offline   Reply With Quote
Old 02-25-2012, 05:00 PM   #15
A "Handy Husband"
rjniles's Avatar
Unhappy
The shill has arrived
Heatpump vs Natural Gas - Energy Cost Spreadsheet zootjeff HVAC 11 06-22-2015 03:59 AM
Home Energy Audit & Spray Foam Insulation sweets Insulation 7 09-08-2011 10:45 PM
What is the cost of adding brick ledge to new construction? toddtx Building & Construction 4 01-13-2011 06:04 AM
cost for replacement window installation timsmeegs Off Topic 2 04-29-2010 01:14 PM
