-   -   Possible way to reduce energy cost??? (http://www.diychatroom.com/f18/possible-way-reduce-energy-cost-134967/)
twobyfour2 02-25-2012 07:55 AM
Hi, I hope someone can let me know about a fairly new product that I saw on a local news network here in Atlanta. It's received coverage on TV as well as some of the local DIY radio shows here. The product is called Energy Crusher which is supposed to reduce your energy consumption by a guaranteed 8%, but could easily save anywhere from 10% - 20%. If that's true, the $329 unit would pay for itself in one year for most homeowners.
I'm including two links here...
one is a youtube demonstration... http://www.youtube.com/watch?v=tPdOy...eature=related
Company site... http://energycrusher.com/index.php/products/
My question to this forum is does this product make sense? I had an electrician from a local company come out to my house last night to demonstrate it. The unit is basically a large capacitor that stores unused energy and on a cycle of every 20 secs, gives that energy back to your electrical system through your neutral bar. (I'm not quite sure I understand it all).
Anyway the electrician said I would need to purchase two units because I have two 'legs' coming into my house's electrical panel. Does that make sense? If I understand him correctly that would mean some of my breakers are fed off of one line coming in and the other breakers are fed off of another line. I think this unit could be helpful, just trying to justify the cost for two units.
Thanks in advance for any comments!
rjniles 02-25-2012 08:09 AM
Snail oil
er: I meant snake oil
HARRY304E 02-25-2012 08:17 AM
Smoke and mirrors.
Don't waste your money..:no:
AllanJ 02-25-2012 08:23 AM
It's probably one of those devices referred to generically as power factor correctors.
However power factor issues are small or non-existent in homes. (Power factor inefficiency can be a problem in industrial settings where there is a lot of motorized tools and equipment. The poorer the power factor, the more kilowatts are supplied by the source to perform the same work.)
It so happens that connecting a capacitor from hot to neutral or from hot to hot (depending on the motor) will cut the overall power draw while the motor behaves the same way performing the same work
Yes you can overcorrect in which case the overall efficiency goes down. If you are not using electricity (the motor is turned off), the capacitors in a power factor correction device left connected will consume power, doing nothing useful.
Pure resistance such as for incandescent lights or baseboard heaters does not have power factor error.
Power factor can be explained using a sailboat as a metaphor. When the wind is behind you you get maximum power with the wind hitting the sail stuck out to the side straight on. The "power factor" is close to 100%.
When you want to sail in a direction other than the wind, you have to set the sail with the wind blowing at a diagonal. You don't go as fast for a given wind speed.
("Correcting the power factor" in sailing would consist of somehow redirecting the wind, which is impossible. You are just fortunate you can move at all; by zig zagging you can eventually get to a destination upwind.)
matt151617 02-25-2012 08:23 AM
Anything "supplied" to the neutral bar is wasted. The neutral and ground bar are bonded in the panel, so anything that ends up in the neutral or ground bar is dissipated into the earth. The power company could care less what you do with the power, after it passes the meter.
Besides, you have one phase coming into the house. The wire is split, 120v each, but there's not multiple phases. It all sounds like a scam.
Jim Port 02-25-2012 09:00 AM
The power returned to the neutral buss is not going into the earth. It wants to return to it's source, the transformer.
mpoulton 02-25-2012 12:38 PM
Er, interesting analogy but not quite right on the sailing. Sailboats can go faster than the wind, and they can only do it when sailing across the wind. The more perpendicular the boat's course is to the wind, the faster it's theoretical maximum speed. In practice there is a limit determined by the sail's efficiency and the boat's drag in the water. http://en.wikipedia.org/wiki/Sailing..._than_the_wind
On the power factor stuff, of course, you're right. And power factor correction doesn't help your power bill unless you're in an industrial setting where the POCO monitors the power factor and charges a penalty for it. Residential meters charge for kilowatt-hours not KVA-hours, so the inefficiency of low power factor is paid for by the POCO not the customer.
Billy_Bob 02-25-2012 01:42 PM
You save money by using less electricity.
Turn things off. Buy "Energy Star" appliances. More, search google.com for the words...
Energy Saving Tips
diy'er on LI 02-25-2012 01:55 PM
you also can save a ton of electricity by unplugging appliances. a lot of appliances continually use some basal level of energy merely by being plugged in... not only things with lights and clocks like microwaves, but also suprisingly blenders, food processors, radios, TVs, the charging cord for your cellphone...
The biggest power hogs are those cable boxes. Even when "off" they're burning tons of energy.
the more you habitually unplug, the more the savings.
jbfan 02-25-2012 02:08 PM
Gotta love the Mr. Sparky ad.
They say savings up to 25%
Like others have said, snake oil.
rrolleston 02-25-2012 03:18 PM
Looks like something that you would see get promoted on one of those stupid infomercials in the middle of the night when you can't sleep and you are trying to find something to watch on TV.
bcohenc 02-25-2012 04:05 PM
Energy Crusher
The Energy Crusher work very well i have had it in my home in New Jersey for the past 13 months each month shows a reduction of KWATTS used The same people who dont think it works are the same people who 30 years ago thought a TANK LESS HOT WATER HEATER WOULDNT WORK EITHER THEY WOULD SAY HOW CAN THIS LITTLE HEATER OF HOT WATER HEAT OUR ENTIRE HOME WELL IT DOES
bcohenc 02-25-2012 04:06 PM
jimmy21 02-25-2012 04:17 PM
39 Attachment(s)
I've never heard a single electrician (that wasn't selling them) say anything good about power factor correctors in a residential application. Motor loads in a house are minor. Heat and ac are what drive up your electrical bill and neither are effected by powrr correction
rjniles 02-25-2012 05:00 PM
The shill has arrived
