Possible Short...I Think? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-01-2013, 01:58 AM   #1
Possible short...I think?
Hi...I came home from work and 15amp for the bedroom was tripped and the 60 AMP was tripped (and loose in the panel). I have an airtron furnace with a 30 AMP and 60 AMP breaker in the panel that both say "Furnace" on them. When I reset the breaker on the bedroom, everything was fine (for that circuit), but when I reset the 60 AMP breaker on the furnace, there was a light flicker and a wubba wubba sound, so I turned it back to off. Now, the furnace is still working while only using the 30 AMP breaker. Any ideas...?
House was a model built in 2006, furnace installed in 2006...
I bought the house in 2008
kieth5555 is offline   Reply With Quote
Old 02-01-2013, 06:53 AM   #2
Rewards Points: 1,548
Are all parts of the furnace working? Or is the blower going while there is no heat or limited heat?
Are there other circuits in the house that are dead even though their breakers are on?
Any unusually dim lights elsewhere? Incandescent lights show this more noticeably.
Is the 60 amp breaker for air conditioning only?
Old 02-01-2013, 07:16 AM   #3
custom user
Rewards Points: 150
My guess is that the 60amp breaker tripped because it was loose. It must be for something other than the furnace, did you tighten it down? Seems odd for such a new house, I guess the installer didn't eat his Wheaties that morning.
JasperST is offline   Reply With Quote
Old 02-01-2013, 08:32 AM   #4
To JasperST: I've pushed it in and it still did the same thing so I cut it off before something blew up in the circuit breaker box...
AllenJ: the AC unit has its own 60 dual pole breaker this furnace has a 30 amp and a 60 amp breaker of its own... No 1 usually demo lights anywhere however I will check out the sockets and everything when I get back with my meter I'm at work now.
Old 02-01-2013, 12:21 PM   #5
Semi-Pro Electro-Geek
Rewards Points: 2,990
The wubba wubba sound is the worst. I think your furnace has two circuits for two different sections of electric heat, and the section powered from the 60A breaker has a short. It may seem to be working, but probably at reduced heating power.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 02-01-2013, 02:49 PM   #6
Yeah that's what I was thinking I went in the attic and check the wires I didn't find anything i have to open up the furnace I think that is where its at.
Carrier furnace short cycling between Low and High heat drtbk4ever HVAC 16 01-15-2012 08:38 AM
Short ciruit with Romex 10/3 cable and cable connectors virago Electrical 21 10-07-2011 08:01 AM
Furnace short cycling repman55 HVAC 12 01-21-2011 04:41 AM
Rheem 80% Furnace Short Cycling rlukas79 HVAC 0 12-19-2010 03:27 AM
Short Circuit but Breaker does not trip vino82 Electrical 6 01-29-2010 12:54 PM
