Possible Scenario? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-04-2010, 05:35 PM   #1
Possible Scenario?
Is this possible? Do you have enough wires to complete a 3way switch by piggy backing your hot lines?
kanxrus is offline   Reply With Quote
Old 12-04-2010, 05:38 PM   #2
Licensed electrician
Rewards Points: 1,266
Do you want both sets to be controlled by 3way switching?
Old 12-04-2010, 05:41 PM   #3
Rewards Points: 1,192
Yes.for only 1 -3-way.
bobelectric is offline   Reply With Quote
Old 12-04-2010, 05:43 PM   #4
Here's the jist, I have a large room. 40' x 15'. I put in 10 can lights. I want to have 2 3-way switches on each side of the room. This way you can turn off half of the lights if your not using that side of the room.
I have a brother-in-law who is an electrician who told me this is possible. He is currently on a cruise and I cannot figure out how to wire this all together.
So short answer, Yes I would like 3-way switches in both boxes.
Old 12-04-2010, 07:09 PM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Yes you have enough wires to install 2 - 3 way switches in each box. White wire from the panel to the white wire of the 12-3. Black from the panel to the common of both 3 way switches in the first box. Use the 12-2 for the travelers of the first switch, use the red, black of the 12-3 for the travelers of the second switch. At the second switch box, connect the white of the 12-3 to the white of the 2 light banks. Connect the common of each 3 way to the black going to its respective light bank.
Coastal South Carolina
Old 12-04-2010, 07:50 PM   #6
joed's Avatar
Rewards Points: 12,002
It can be done, but i am not sure it will be to code since the neutral wire will be in one cable and switch power lines will be in the other cable for one of the switches. Code requires hot and neutral to be together in the same cable or conduit.
How to wire it.
Two gang box right.
Power black to black screw on each three way.
Power white to white in 12/3 cable.
12/2 black and red to travellers on one switch.
12/2 black and white to travellers on other switch.
At left two gang box.
12/3 white to both light whites.
Light blacks, one each, to black screws of the three ways
red and white from 12/3 to one switch travellers
black and white from 12/2 to other switch travellers.
Old 12-05-2010, 09:46 AM   #7
Originally Posted by rjniles View Post
Yes you have enough wires to install 2 - 3 way switches in each box. White wire from the panel to the white wire of the box.
Do I have to disconnect the white wire from inside my box?
Old 12-05-2010, 10:52 AM   #8
A "Handy Husband"
rjniles's Avatar
Not sure of your question. Here is what I said:
"White wire from the panel to the white wire of the 12-3. Black from the panel to the common of both 3 way switches in the first box.---etc"
Old 12-05-2010, 02:10 PM   #9
Sorry I meant panel, I got it all wired up!
Thanks, you guys rock!
Old 12-05-2010, 02:55 PM   #10
Rewards Points: 6,652
My Dining room light is wired from the panel to the 3-way in the kitchen, then over to the light, then the last 3-way in the Dining Room. Shortest and easiest way to wire. Bring into the first gangbox from the panel, then come off of that for all lights that on that circuit.
Old 12-05-2010, 03:06 PM   #11
A "Handy Husband"
rjniles's Avatar
While your wiring method will work, it is not what the OP asked. He wanted to know if the existing wires he had in place could be used to connect up the 2 pairs of 3 way switches. If he were going to place new wiring, I would have suggested he run two 12-3 cables between the switch boxes. Running the 12-3 to the light fixture boxes as you suggest would not be practical in his scenario.
crown molding sloping wall and standard wall Alex007 Carpentry 12 03-13-2010 09:56 AM
Tiling entryway - proper transition for this scenario? Scott99999 Flooring 5 12-22-2009 01:12 AM
Understanding 120V branch loads in 100A 240V system WaldenL Electrical 17 02-17-2009 10:15 AM
Where do we go from here? astounded General DIY Discussions 3 03-26-2008 09:20 AM
