Old 09-25-2007, 05:57 PM   #1
Possible to remove a button on/off?
Dealing with small helmet light, basically a flashlight. Is it possible to remove the button that turns it on and off and cycles through the different light modes? Can I hardwire it to a switch for simply on/off?
Alpha Crow is offline   Reply With Quote
Old 09-27-2007, 06:54 PM   #2
If you can find a switch to fit your light or can make one work you just simply need a regular on/off switch (example: instead of an on/on/on/off switch you need an on/off). Check with Grainger.com or an electrical supply house.
surferjak is offline   Reply With Quote
Old 09-27-2007, 07:20 PM   #3
I have gas!
Clutchcargo's Avatar
Sounds like one of the NiteRider lights. If that's the case then you have to bypass the circuit in the light. Have you taken it apart yet to see what's inside?
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
remove steam radiator rick2665 HVAC 11 03-09-2010 08:29 PM
How do I remove this ceramic tile? tripower Flooring 5 07-23-2007 10:45 PM
remove damage vinyl tiles harold938 Carpentry 2 11-16-2006 01:14 AM
Remove baseboard heat? Patrick B HVAC 6 04-11-2006 05:12 PM
Want to remove wall found heating/ducts wondrgirl HVAC 2 06-04-2005 11:54 AM
