Is It Possible To Override IR Sensor With Single Switch? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-13-2011, 12:28 PM   #1
Question
Is it possible to override IR sensor with single switch?
Hi
I'm installing an outdoor twin flood light with motion sensor and I am thinking of using a single pole wall switch to bypass the ir sensor when desired. Is the following install viable ?
The incoming power(Hot) is connected to one hot leg of sensor along with one leg of wall switch. The output leg of sensor and wall switch now go directly to the both hot wires of the floods.
The incoming Neutral is direct to neutral legs of sensor and floods.
Will this configuration allow the wall switch to over ride the sensor and power the flloods although no motion is detected ?
FYI The light fixture model is a Heath/Zenith SL-5412
I have tried to attach a crude schematic of my plan,not sure if it attached.
torizus is offline   Reply With Quote
Old 03-13-2011, 12:52 PM   #2
I=E/R
a7ecorsair's Avatar
Electrically it would work but what you do not know is how the IR circuit is made. You would be placing line voltage on the output side of the IR device when it could be in the inactive state which would be OK if the output is a mechanical relay. If it is some type of solid state device it may damage it.
a7ecorsair is offline   Reply With Quote
Old 03-13-2011, 01:13 PM   #3
Master Electrician
Rewards Points: 3,808
You need a 3-way switch. Connect the power to the common screw. In one position the power will be switched through to the IR sensor. switched to the other position power will be supplied directly to the fixture.
brric is offline   Reply With Quote
Old 03-13-2011, 01:43 PM   #4
Rewards Points: 282
lol..
no. dont do this.
buy a motion flood light with override (typically turn light switch on, then off, then on within 1 second and it will manually turn light on and leave it on).
they are abundantly common.
jcrack_corn is offline   Reply With Quote
Old 03-13-2011, 02:54 PM   #5
I=E/R
a7ecorsair's Avatar
He doesn't need a different light, he needs to read the manual
Is it possible to override IR sensor with single switch?-heath-motion-lite.jpg
Old 03-13-2011, 03:05 PM   #6
Thanks for the quick responses, introducing line volt into the sensor output is my main concern but most likely only a Zenith engineer could confirm it. That prob ain't gonna happen.
My primary objective was to somewhat illuminate an area outside of the motion sensors directed focus. This is to check my field prior to allowing my dogs out, the sensor is directed at the patio and rear doors but not the doors that the dogs come out of,which will not trigger the sensor. This model does have the reset feature as you suggested, I guess using that is being sure and safe as opposed to taking chances on the alternative.
Thanks for opinions.
Single Pole Switch, but 5 wires in wall and ceiling jmo1112 Electrical 4 10-11-2010 08:51 PM
Convert single pole switch to a 3 way! Wildie Electrical 19 05-13-2010 10:20 AM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
Help with single pole switch ballutster Electrical 2 10-13-2008 07:57 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
