Is It Possible To Enlarge A Junction Box? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-13-2013, 02:49 PM   #1
is it possible to enlarge a junction box?
The attached picture is of the junction box where the wires enter my house. It's about 4.75 x 4.75 x 6 inches, and crammed full. The picture doesn't do justice to just how jam-packed it really is, since you can't see past the first "wave" of wires.
So, I'm wondering whether there is any way to enlarge this box without ripping it out (which would be a big job). Or, is it possible to installing a new box without disconnecting all of the wires? At present, it's not practical to extend the box out further from the wall, since there's a water heater in the way. Of course, if moving the water heater is the only option, I could probably manage it. Anyways, I'm just wondering whether there might be a clever solution to this sort of problem. Thanks.
Jeremy Hillary Boob, PhD is offline   Reply With Quote
Old 01-13-2013, 02:59 PM   #2
Rewards Points: 12,802
Nope, I think I'be spending some time how to run some of those wires differantly so there not all just coming to there.
Only way to the wires out is to disconnect them.
Old 01-13-2013, 05:41 PM   #3
Rewards Points: 320
Looks like the box already has an extension ring on it but you could probably install another one to extend it. I don't see the water heater in the picture so it is not clear how it would be in the way. First thing I would do is take wire count and properly calculate the box fill. I would only recommend this as a temporary fix. As Joecaption said the best way to do it would be to figure out a better way to run the wires.
teamo is offline   Reply With Quote
Old 01-13-2013, 05:45 PM   #4
Code05's Avatar
Rewards Points: 1,104
That is an extension ring mounted to a regular box.
Code05 is offline   Reply With Quote
Old 01-13-2013, 06:43 PM   #5
Rewards Points: 6,652
I would have to say, that box is well past its fill. You wonder why Electricians get paid so well to fix others "fixes".
Old 01-13-2013, 08:47 PM   #6
Thanks for all of the responses.
Yes, it's certainly going to take some hours to fix the mess. I don't know how it got so screwed up, but it wasn't my doing. I've spent lots of time since we moved in (about 5 years ago) fixing electrical problems and this is the last major thing---at least it's the last one I know about. Maybe it's time to stop looking. Anyways, I'll eventually bite the bullet and do it right. Things like this bug me, even if it's been there for 20 years without causing any problems.
Old 01-13-2013, 09:32 PM   #7
dmxtothemax's Avatar
Rewards Points: 5,096
Originally Posted by Jeremy Hillary Boob, PhD View Post
So, I'm wondering whether there is any way to enlarge this box without ripping it out (which would be a big job). I'm just wondering whether there might be a clever solution to this sort of problem. Thanks.
Why do you need to enlarge it ???
Do you intend to add further wires to it ?
Or is it purely cosmetic reasons ?
dmxtothemax is offline   Reply With Quote
Old 01-13-2013, 09:41 PM   #8
Electrical Contractor
jbfan's Avatar
Rewards Points: 138
It already has an extension ring on that box.
Installing Light on Round Junction Service Box MegR Electrical 7 07-07-2013 09:31 PM
Temperature in junction box buried under R49 insulation (heat detectors/smoke alarm) darlingm Electrical 2 01-16-2012 04:55 PM
Garage feeder junction box bonding WillK Electrical 0 06-05-2011 11:03 AM
Installing ceiling fixture with a metal junction box Romanuke Electrical 12 03-20-2011 03:37 PM
Junction boxes for garage T8 fixtures mazeroth Electrical 13 01-25-2010 10:52 PM
