Is It Possible To Add A Receptacle To A 3-way Switch? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-04-2010, 09:51 AM   #1
Is it possible to add a receptacle to a 3-way switch?
The power goes from the light fixture to the first switch.
If it's possible, where shall I put the receptacle? Before or after the switches?
ellem is offline   Reply With Quote
Old 09-04-2010, 10:25 AM   #2
joed's Avatar
Rewards Points: 12,850
If you only have one 3 wire cable or a 3 wire and 2 wire cable then it is not possible if the power goes the fixture first. There is no neutral present in the switch box.
The Following User Says Thank You to joed For This Useful Post:
ellem (09-05-2010)
Old 09-04-2010, 10:34 AM   #3
Rewards Points: 855
the only recommended place to tap off the unswitched incoming power is the first box in the circuit it comes into.
TimPa is offline   Reply With Quote
The Following User Says Thank You to TimPa For This Useful Post:
ellem (09-05-2010)
Old 09-04-2010, 09:35 PM   #4
joed's Avatar
Not true. You can tap power from any junction box on the circuit with unswitched power.
ellem (09-05-2010)
Old 09-05-2010, 01:12 AM   #5
" Euro " electrician
frenchelectrican's Avatar
Not alway the case you can tap in somewhere else but there are few area it is off limit is Kitchen circuits , outside recetales , Bathroom , Garage { that my part it off limit anyway }and dinning room as well due some of the dinning room use the SABC as well so that is off limit.
So those following room is off limit when you do the tapping to other junction boxes.
Those listed room have it own circuit per NEC code { CEC as well }
Merci.
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
ellem (09-05-2010)
Old 09-05-2010, 09:46 AM   #6
Rewards Points: 855
you're right, that implies universally agreed upon. i should have worded it as i recommend tapping power in the first box, as tapping it in a 3 way swirch box is not fun. and, since power entered the light box first on the op's circuit, it would have made determining the hot wire another obstacle for him.
ellem (09-05-2010)
Old 09-05-2010, 01:00 PM   #7
Thanks for all the responses. I guess it's not really possible. I made an attempt, with the result that I get power to the outlet only when the lights are off? 3-way switch works fine though.
Old 09-05-2010, 05:17 PM   #8
Rewards Points: 1,512
A reminder, the neutral you need/use must be in the same cable (ergo come from the same tap point) as the unswitched power you are using.
Adding a Hot Receptacle to a 3-Way Switch Coady Electrical 2 09-03-2010 12:11 PM
New pressure switch and inducer and still incorrect drafting kevintabb HVAC 5 01-19-2010 12:59 PM
Switched receptacle wiring problem. sheshore Electrical 6 09-27-2009 01:37 PM
Switch / Receptacle mikbro Electrical 11 10-31-2008 04:15 PM
changing a fixture to an outlet - keeping the switch aweshucks Electrical 4 12-27-2007 05:06 PM
