Possible 404.9(B) Violation - Electrical - DIY Chatroom Home Improvement Forum
Old 04-22-2013, 10:42 PM   #1
Rewards Points: 14
New member here. EE grad dealing mostly with DC electronics and a couple summers of experience with a commercial contractor.
So I moved into a new house about a year ago (Built mid 2011) and I was repainting my bathroom yesterday and when I removed the switch covers I noticed the switches weren't grounded. I then removed multiple switch covers around the house and they all were the same as the original. All boxes are plastic and the copper grounding wires are bunched up in the rear of the boxes.
Should this be corrected? I still have warranty under the builder for this, so they would be the ones to correct it.
Also, when I removed the array of lights above the vanity mirror I saw it wasn't grounded either, but I couldn't find a code on this one.
I know they chances of this being an issue is slim, but I do believe in having everything to code. What do you guys think?
I know when I worked commercial we had an inspector check our work every step that we took but I don't quite know about residential besides the inspections completed by the buyer of the house, which I know wouldn't have caught this due to not being able to remove parts of the home.
sheltonfilms is offline   Reply With Quote
Old 04-22-2013, 10:50 PM   #2
Architectural Sculptor
RWolff's Avatar
Rewards Points: 502
Looks like another "pro" chop job there, despite a license and all the rest, clearly they didn't matter when the guy who put these in just decided to heck with it no one will see it, and rushed the job then put the covers on and got his check.
Another reason not to trust someone else's work, and to always check things like this with your own eyes and verify it's right.
That job is about what a novice do-it-yourselfer would have done using a "how to" book, but he skipped chapter 5 or something.
Slim, untill something happens- there's no ground there, I'd say that's an issue!
RWolff is offline   Reply With Quote
The Following User Says Thank You to RWolff For This Useful Post:
gregzoll (04-23-2013)
Old 04-22-2013, 11:01 PM   #3
everything electrical with any metal should be grounded. especially if it has a green ground screw
jdoubleu is offline   Reply With Quote
The Following User Says Thank You to jdoubleu For This Useful Post:
RWolff (04-22-2013)
Old 04-22-2013, 11:20 PM   #4
Power Gen/RS Engineer
Rewards Points: 566
In that second photo (which looks like part of a lighting fixture body), how hard would it have been to connect the ground to the green stud marked GND?!
I hate ****ty installs.
Well, now, there's what's right and what's right and never the twain shall meet.
BigJimmy is offline   Reply With Quote
The Following User Says Thank You to BigJimmy For This Useful Post:
RWolff (04-22-2013)
Old 04-23-2013, 12:18 AM   #5
Yes those grounds should be connected!
Shameful electrical work! I would check every single electrical thing in the house and report this to the electrical inspector.
Don't forget to check the electric water heater if you have one and 240 volt appliance outlets, outdoor outlets, etc.
Sometimes there are junction boxes in an attic or crawlspace, look for those.
P.S. Inform your neighbors if it is a housing development.
Billy_Bob is offline   Reply With Quote
Old 04-23-2013, 01:56 AM   #6
Rewards Points: 506
Send a message via AIM to theatretch85
I think that light fixture needs to be installed over a box, that looks like the cable just comes in through the back and is just screwed right to the wall.
theatretch85 is offline   Reply With Quote
Old 04-23-2013, 06:01 AM   #7
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
I concur, the light fixture does indeed need to be installed over a fixture box.
Old 04-23-2013, 06:19 AM   #8
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,872
Doubtful. Looks to me like another all-in-one contractor job. I see them all the time here in NY where no licensing is required in most areas.
The Following User Says Thank You to Speedy Petey For This Useful Post:
stickboy1375 (04-23-2013)
Old 04-23-2013, 06:49 AM   #9
E2 Electrician
Working in NY scares me with some of the stuff I come across, I call the locals 'woodchucks', completely different lifestyle for sure...
The Following User Says Thank You to stickboy1375 For This Useful Post:
Speedy Petey (04-23-2013)
Old 04-23-2013, 07:14 AM   #10
It kills me when I ask some small time GC "Who does your electrical and plumbing?", and the reply is "Oh, I do it all."
Old 04-23-2013, 07:25 AM   #11
Rewards Points: 528
I do a lot of electrical and plumbing work. As far as the electric is concerned, we do have independent electrical inspectors that are supposed to inspect all electrical work.
framer52 is offline   Reply With Quote
Old 04-23-2013, 11:27 AM   #12
Rewards Points: 14
Probably didn't connect it since the other end wasn't connect to anything either.
Can you guys explain why you think the plate should be on a fixture box?
Old 04-23-2013, 03:54 PM   #13
I love my inspector. With that said, they are not exactly the most thorough bunch in NYS. Some are downright shameful as to what they miss or let go.
I don't EVER want to hear "It passed inspection. So I know the job is done properly."
Old 04-23-2013, 06:32 PM   #14
E2 Electrician
Because an electrical box is required for every fixture, only a few exceptions exist, and in your picture, it isn't one of them.
Old 04-23-2013, 06:34 PM   #15
E2 Electrician
And then we have people giving terrible advice for free on the internet with crappy inspectors allowing it...
electures (05-05-2013)
Is there a violation venting windowless a/c? dataguy HVAC 12 10-16-2011 05:34 AM
Attached garage, fire codes violation? Grymph Building & Construction 38 07-04-2011 06:57 PM
Code Violation? rdtour Building & Construction 9 01-16-2010 11:31 AM
Violation? DangerMouse Electrical 28 05-18-2009 09:00 PM
