Possible? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-18-2012, 10:10 PM   #1
Rewards Points: 164
Possible?
Ok.....so to start out i'm not even sure this is possible.....but here goes.
I'm buying this...
http://www.harborfreight.com/2-hp-in...tor-97869.html
And I was planning on putting it the back corner of the shop way behind everything out of the way....which would make it difficult to access to turn on and off. Ok to make the outlet its going to plug into switched and just use that to turn it on and off....always leaving the switch on it in the on position?
ryan50hrl is offline   Reply With Quote
Old 07-18-2012, 10:36 PM   #2
Rewards Points: 13,960
Sure as long as you leave room to service it.
Old 07-18-2012, 10:37 PM   #3
dmxtothemax's Avatar
Rewards Points: 5,486
So what exactily is your question ?
dmxtothemax is offline   Reply With Quote
Old 07-18-2012, 10:37 PM   #4
Rewards Points: 164
Now...any way to do it If I instead got a 220 unit?
Old 07-18-2012, 11:14 PM   #5
Rewards Points: 506
Proper 240v receptacle, 240v circuit, and a properly rated DPST switch. Same procedure, different components.
jlmran is offline   Reply With Quote
Old 07-18-2012, 11:17 PM   #6
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Either way, you would need a HP rated switch.
Old 07-19-2012, 05:01 AM   #7
Master Electrician
Rewards Points: 3,916
Mine is controlled by a remote transmitter and receiver.
brric is online now   Reply With Quote
