-   -   Possible? (http://www.diychatroom.com/f18/possible-150745/)
ryan50hrl 07-18-2012 10:10 PM
Possible?
Ok.....so to start out i'm not even sure this is possible.....but here goes.
I'm buying this...
http://www.harborfreight.com/2-hp-in...tor-97869.html
And I was planning on putting it the back corner of the shop way behind everything out of the way....which would make it difficult to access to turn on and off. Ok to make the outlet its going to plug into switched and just use that to turn it on and off....always leaving the switch on it in the on position?
joecaption 07-18-2012 10:36 PM
Sure as long as you leave room to service it.
dmxtothemax 07-18-2012 10:37 PM
So what exactily is your question ?
ryan50hrl 07-18-2012 10:37 PM
Now...any way to do it If I instead got a 220 unit?
jlmran 07-18-2012 11:14 PM
Proper 240v receptacle, 240v circuit, and a properly rated DPST switch. Same procedure, different components.
k_buz 07-18-2012 11:17 PM
Either way, you would need a HP rated switch.
brric 07-19-2012 05:01 AM
Mine is controlled by a remote transmitter and receiver.
