Positive Vs Negative Wires In Power Cable - Electrical - DIY Chatroom Home Improvement Forum
Old 03-28-2010, 11:59 AM   #1
Positive vs negative wires in power cable
I am replacing a power cable on a small appliance. The old cable is all black with one side ribbed and the other side smooth and no white line running down the length at all. Which side corresponds to white and which to black? In a simple circuit such as this I believe it doesn't really matter, but I'd rather be safe by doing it right the first time and not just trying it by plugging it in to see if something shorts out or starts smoking.
HeavyD is offline   Reply With Quote
Old 03-28-2010, 12:19 PM   #2
Heavy D, It depends on the appliance. Some are sensitive to the hot and neutral being switched, but on most home stuff it doesn't matter. I'm assuming there is no ground prong involved? Are you connecting the new cord at the terminals of the appliance or just splicing on a new piece?
Regards,
Kilowatt56
kilowatt56 is offline   Reply With Quote
Old 03-28-2010, 12:34 PM   #3
Rewards Points: 1,506
There is a rule or convention for ribbed versus smooth but I don;t know what it is!
Ergo you will find numerous times when it is backwards. Particularly if someone was assembling all three separate components -- plug, cord, rest of appliance.
The smaller of the two plug prongs is the hot (i'll let you get away with saying positive) and that should go to the on-off switch of the appliance. The neutral should go to the socket shells and the hot to the socket bottom contact if light bulbs are involved.
Old 03-28-2010, 12:52 PM   #4
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
The ribbed conductor in a zip cord is the Neutral
The smooth conductor is the Hot.
Disclaimer
& Stay Safe
.....Bob Lavery
The Following User Says Thank You to PaliBob For This Useful Post:
fpeftw (05-31-2010)
Old 03-28-2010, 01:07 PM   #5
My puppy chewed through the power cord of my paper shredder. (It was unplugged at the time.)
The power cord I want to repair it with is from a failed hand-held vaccum cleaner. the vaccum was barely used and I think the power switch went bad. Of course, it might have failed from a bad power cord but I doubt it. I should use a continuity tester to confirm the condition of the replacement cord but I don't have one so I am hoping that this is a simple enough repair that I don't really need one.
The replacement cord is round with a black wire, white wire and a phased prong and is the same gauge as the original. There is no third wire involved.
Does it matter if the ribbed side is connected to the white or the black wire?
Old 03-28-2010, 01:15 PM   #6
Tool Geek
PaliBob's Avatar
Thumbs up
Originally Posted by HeavyD View Post
...........Does it matter if the ribbed side is connected to the white or the black wire?...
Good news on the puppy
ribbed goes to white
smooth goes to black
Disclaimer
& Stay Safe
.....Bob Lavery
Old 03-28-2010, 01:57 PM   #7
Electrical Contractor
kbsparky's Avatar
As stated elsewhere in this thread, the ribbed conductor is the neutral, and connects to the white.
It should also be stated that this is not an issue of positive vs negative, since we are dealing with alternating current.
By definition, alternating current -- AC as it is commonly referred to -- changes from positive to negative and back again 60 times every second. Or in the case of other countries and systems -- 50 times per second. This action is known as cycles per second, or Hertz.
-KB
Old 03-28-2010, 02:07 PM   #8
The puppy has moved on to chewing belts and straps on flip-flops.
I have used the terms positive and negative but that seems to be incorrect. I should be saying hot and what? Which is which?
Thank you for the direct answer on ribbed ande smooth. Works for me.
Old 03-28-2010, 09:07 PM   #9
electrical instructor
the ribbed conductor is the neutral and the smooth conductor is the hot. the reason is, the ribbed conductor is connected to the neutral prong of a rec.,the ribbed side of the cord is connected to the screw shell of a light so when you unscrew the light bulb, the bulb is no longer hot as soon as you are no longer touching the tongue at the bottom of the screw shell and many appliances have electronic circuit boards in them that are polarized (current needs to be moving in a certain direction)
bhound84 is offline   Reply With Quote
Old 03-28-2010, 09:28 PM   #10
Rewards Points: 1,192
Appliance or lamp cord has one conductor "identified" by ribs or white lines to indicate it is the grounded conductor.This is commonly called the neutral wire.
bobelectric is offline   Reply With Quote
Old 03-28-2010, 11:24 PM   #11
Power Gen/RS Engineer
Rewards Points: 566
Wow!
I've taken quite a vacation from this site and I'm glad to see that the questions haven't changed, LOL!
Jimmy
Well, now, there's what's right and what's right and never the twain shall meet.
BigJimmy is offline   Reply With Quote
Old 03-28-2010, 11:26 PM   #12
Rewards Points: 506
Victory for Tesla!
jlmran is offline   Reply With Quote
Old 03-29-2010, 01:27 AM   #13
" Euro " electrician
frenchelectrican's Avatar
Originally Posted by BigJimmy View Post
Wow!
Jimmy
Accueil BigJimmy { it say Welcome back BigJimmy }
Ya been busy ?
sorry for getting off topic
But for North Americians cords the ribbed side is always netural or white one of the two and also if you see the stamp or marking if on one side that is on netrual { that useally show up on zip cords }
For European cords the netural side it will be on ribbed side and also marking on one side and for colour code it will be either Bleu { modern code } or black { old code } that for only netural conductor only.
{ the line side for European cords will be either Brown { new code } or Red { old code } }
Merci,Marc
Old 03-30-2010, 12:45 PM   #14
Rewards Points: 130
A shout out to Big Jimmy. Good to see you back. Hang around a little bit.
J. V. is online now   Reply With Quote
Old 05-31-2010, 02:56 PM   #15
Thanks PaliBob and all...
Wanted to thank you for your information as it helped me a great deal when splicing a piece of grounded outdoor extension cord to my old refrigerator when the plug went bad.
dhowe is offline   Reply With Quote
Adding a wall switch to a pull chain fixture abacuslearns Electrical 17 12-20-2011 06:02 PM
Can't find the wires! brianmarsh Home Theater 2 01-24-2010 07:11 AM
four wires inside a cable?! joeyboy Electrical 23 11-05-2007 10:31 AM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 02:54 PM
I really need help! POOK Electrical 34 04-20-2007 07:01 PM
