Positive And Negative Wires - Electrical - DIY Chatroom Home Improvement Forum
Old 08-16-2012, 02:23 PM   #1
positive and negative wires
Hello
My name is Sam and i am an amateur at electrical work, and i was wondering, if i have several positive and negative wires, how can i funnel them into one positive wire and one negative?
If someone could help me out i would really appreciate it
thanks
sam
asm123 is offline   Reply With Quote
Old 08-16-2012, 02:40 PM   #2
Rewards Points: 12,868
A wire nut.
Old 08-16-2012, 02:51 PM   #3
Originally Posted by joecaption View Post
A wire nut.
And you also have to make sure all the voltages are the same.
jeepdawg is offline   Reply With Quote
Old 08-16-2012, 03:53 PM   #4
Rewards Points: 776
Originally Posted by asm123 View Post
Hello
thanks
sam
Hello Sam,
I am afraid it is not quite so simple. First they aren't positive and negative, they are hot and neutral. Further there are two phases of hots and if you connect them you put a dead short across a 240VAC circuit. Quite nasty . Lastly, you cannot connect hots together from different branch circuits even if they are the same phase. That would be in effect back feeding a circuit and rendering the breaker's protection useless.
Can you elaborate on the specific case that might help get to a better response.
curiousB is offline   Reply With Quote
Old 08-16-2012, 04:25 PM   #5
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Hello
thanks
sam
Sam
Is this DC (direct current) wiring or AC (alternating current) like in your homes wiring?
Old 08-16-2012, 04:36 PM   #6
Rewards Points: 660
Go to Home Depot (Lowes, Menards, etc.) and spend $20 on a "How to" book. I am serious, that helped me get a start on DIY work. Judging from your question, you are not ready to jump in the pool just yet.
B
Beepster is offline   Reply With Quote
Old 08-16-2012, 05:38 PM   #7
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Some of the amateurs here seem to like the Black & Decker book. I have never seen it myself.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 08-16-2012, 07:07 PM   #8
dmxtothemax's Avatar
Rewards Points: 5,098
Hello
thanks
sam
Most would say to just "wire nut them"
however things arn't that simplistic.
Please tell us more about these wires ?
and where they are in your wiring system ?
Because some places you can connect them together !
And other places you cannot !
So we need to know more !
dmxtothemax is offline   Reply With Quote
Old 08-16-2012, 07:33 PM   #9
UAW SKILLED TRADES
Stubbie's Avatar
It's probably one of the better ones for homeowners ... as you know there is no replacement for knowing the why of electrical wiring, grounding and bonding but the graphics in that book are covering the most common work done by homeowners. There are actually two of them one is called the 'advanced version'. Frankly some of our trade text books would not be understood by a homeowner without the classroom instruction and field experience that goes along with them. Soares can at times make me scratch my head.
Old 08-16-2012, 08:18 PM   #10
Electrical Contractor
kbsparky's Avatar
I prefer "Practical Electrical Wiring" originally written by H.P. Ritcher.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
electures (08-18-2012)
Positive vs negative wires in power cable HeavyD Electrical 15 05-05-2012 06:05 PM
positive or negative wires Simon Choveaux Electrical 9 01-26-2012 06:57 AM
overhead light fixture has 9 wires? pokey1984 Electrical 8 11-14-2011 09:04 PM
Hooking up a stove range, all wires are black how do tell which is positive and negative and ground? darugg Appliances 4 09-17-2010 09:19 AM
Positive, Negative sides calabashfire Electrical 10 09-25-2006 07:29 PM
