On In On Position And In Off Position!!! - Electrical - DIY Chatroom Home Improvement Forum
Old 03-16-2008, 02:41 PM   #1
on in on position and in off position!!!
Hi,
Ive just moved into an newly refurbed house but in one of the bathrooms the light is always on with switch in either on or off position.
Is there anything I can check before calling out a electrician?
Thanks.
Jim
jimllshiftit is offline   Reply With Quote
Old 03-16-2008, 02:43 PM   #2
Building and plumbing
USP45's Avatar
Rewards Points: 150
Change the switch. May be broke. Make sure to turn the breaker off first
USP45 is offline   Reply With Quote
Old 03-16-2008, 02:54 PM   #3
Replacing a switch is one of the few thins I would say a homeowner could do safely.
Turn off the power, remove four screws, remove/replace. I did it when I was 14 years old.
220/221 is offline   Reply With Quote
Old 03-16-2008, 10:00 PM   #4
If the light is always on, how do you know that you are operating the correct switch for that light? Check the other switches in the house (even if they don't seem to be remotely close). If you just purchased the house after being remodeled by someone else, they may not have known what they were doing, playing electrician. If you can't find a switch that works, call someone that knows what they are looking for and have that circuit traced out correctly.
hammer is offline   Reply With Quote
Old 03-16-2008, 10:55 PM   #5
Cow
I don't know about that. I've been on a call to troubleshoot a bathroom light switch before. Turns out the homeowner had replaced the 3-way switch with a SP because it had the same number of screws!!("No sir, the black does not go to the ground screw.") Funny part was, it was the bosses father-in-law!
Cow is offline   Reply With Quote
Old 03-17-2008, 02:54 PM   #6
Ive definately got the right switch because the light turns off when the switch is half way between the on and off position. This is a house in spain im in. Im not sure if UK switches do that.
Have tried a known working switch and still the same problem. What next?
Old 03-17-2008, 02:57 PM   #7
joed's Avatar
Rewards Points: 13,712
If you remove the switch and just have the two wires hanging does the light come on? If not then something about the switch is not right. All the switch does is connect the two wires together and disconnect them apart.
New thought.
Maybe you have some sort of low voltage control system and you need a momentary contact switch.
Old 03-17-2008, 06:57 PM   #8
The problem is in the wiring make up.
Someone need to take thins apart and see what is wrong. Kinda tough over the net without detailed info on the number of wires, voltage etc.
Installing an island on floating engineered wood floor funktional Flooring 11 03-14-2008 06:19 AM
