Old 05-25-2012, 08:49 AM   #1
Portable generator has no output. Briggs Stratton 5500, model 01646
Generator has no output. I am hoping that flashing the field will get it producing.
Peljay1950 is offline   Reply With Quote
Old 05-25-2012, 09:03 AM   #2
joed's Avatar
Let us know how it goes.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 05-25-2012, 10:19 AM   #3
Flash away. btw what is flashing the field?
Before doing that have you tried the basics. Engine running? Breakers or fuses tripped? Measured voltage at all outputs with a DVM? Any unusual noises or sound from generator or engine? Have you tried connecting a simple load like an incandescent light bulb?
curiousB is offline   Reply With Quote
Old 05-25-2012, 10:53 AM   #4
Average Joe/ex-Navy IC3
gregzoll's Avatar
Flashing the field is taking a drill and running it. What is most likely wrong with the OP genset, is either a bad capacitor, diode, or rectifier.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 05-25-2012, 03:57 PM   #5
Flashing the feild MAY get it going !
But other thinks could be wrong !
Like a faulty regulator !
I would not recomend an inexperienced person flashing the feild !
There are many dangers, if not done correctily.
dmxtothemax is offline   Reply With Quote
Old 05-25-2012, 07:07 PM   #6
It was a dark and stormy
Yoyizit's Avatar
See the schematic on page 14
http://bsintek.basco.com/BriggsDocum...uFGtPlsZVj5K1w
Possibly that resistor symbol in the diode bridge is a heavy duty thermistor that serves as a voltage regulator.
One easy check, with the engine off, is to check that you read an ohm or so across the receptacle slots
Item #6 on pg. 19 seems to be a brush holder so check that the brushes are not excessively worn.
If the manuf. will help us out by supplying voltage/current levels for the excitation coil on pg. 14 then the diode bridge and regulator can be checked.
If not, replace item #6 and hope that it failed for reasons internal to itself. Otherwise the new one will promptly smoke.
briggs stratton model 40320 7kw emergency home generator doug preston Electrical 5 06-24-2011 03:35 PM
Briggs Stratton wont start - 12hp model: 498027 inetquestion Landscaping & Lawn Care 2 04-16-2010 07:57 PM
Briggs and Stratton generator part Jeremy Hillary Boob, PhD Electrical 3 01-10-2009 11:36 AM
Briggs and Stratton Murray lawn mower issues golfer2b Landscaping & Lawn Care 3 08-01-2008 10:42 PM
