Portable Generator Electrical Ground - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 01-13-2011, 12:14 AM   #31
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Yep it sure is. So how about this .. do not use a ground rod on a portable generator ... .. unless your paranoid about lightning
Just thought somebody might like to know why ..
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 01-13-2011, 07:16 AM   #32
the Musigician
DangerMouse's Avatar
Originally Posted by jlmran View Post
And who is complicating things? That's a long post...
Gee, I thought it was was spot-on and to the point! Now if you want REAL detailed explanations....... Nestor Kelebay, come back! We miss you!
DM
Old 01-16-2011, 01:35 AM   #33
DM
Exactly my understanding:
If your generator has a floating ground then you do not need to ground when connecting to the home system, but you should ground if operating stand-alone. (my brief summary)
DennisClawson is offline   Reply With Quote
Old 01-16-2011, 08:47 AM   #34
Rewards Points: 506
Originally Posted by Stubbie
Let the generator be your guide ...
... By that I mean is your portable neutral bonded to frame or is it not bonded to frame. Remember this while we discuss this
stubbie
Are there portable gens. available in the market which are manufactured without a N-G bond?
jlmran is offline   Reply With Quote
Old 01-16-2011, 09:46 AM   #35
Rewards Points: 1,442
Originally Posted by awdblazer View Post
with a generator you are creating your own 120/240 circuit correct? well where do you get that 120 from a 240? it is centre tapped and grounded, well with your house that is a different system than the generator ...
The typical consumer or household generator is center tapped and then it gives you 120 volts as well as 240. It may or may not be "grounded" by having (or not having) the neutral bonded to the generator frame perhaps using a removable green headed screw.
Bonding of the generator neutral to ground will also happen when the generator is used to power a home electrical system via the main panel.
Old 01-18-2011, 05:53 PM   #36
Rewards Points: 280
I put a meter to the generator frame and Nema plug ground plate. Reads continuity.
As a side note, when the power company installed the transfer switch (awhile ago), we did a power On check with the generator connected and running. Power to the CB panel was correct.
I'll hold off on the ground rod.
Earnie is offline   Reply With Quote
How to connect ground wires? Iva Electrical 3 10-29-2010 01:13 PM
To ground or not to ground Red Squirrel Electrical 2 10-14-2010 09:42 PM
Wiring an outlet using both ground screws instead of pig-tailing together. cabber24 Electrical 5 08-26-2010 09:40 AM
Electrical Ground Problem cabinetman Electrical 15 01-28-2010 05:55 PM
Panel ground questions Joe F Electrical 12 08-05-2008 10:48 AM
