Portable Gen Set - Home Connections & Distance - Electrical - DIY Chatroom Home Improvement Forum
Old 06-15-2012, 10:35 PM   #1
Please advise on this design. I'm concerned about the distance and voltage drop, but want to keep the noise down and the gen set out of street view.
1. Portable gen set (gas, 3000w 125v 25a) connected via 50 Ft outdoor cable (Generator Extension Cord 50 Foot 10/3 30 Amp 3 Prong)to Power Inlet Box (30 amps 125 volts).
2. Power Inlet Box connected to a 50 Amp Manual Transfer Switch at an interior distance of 50 wire feet using 8/3 cable, permanently installed.
3. Transfer Switch connected to 200 amp Main service with 8 circuits wired for the portable backup.
I recognize this is small gen set and has limitations in powering part of a residence with only 30 amps. I also recognize the cost of installing 8/3 cable in lieu of placing the gen set closer. 8/3 would allow me to step up later with a larger gen set (50 amps) provided I upgraded the appropriate transfer switch & main panel breakers.
This setup also allows me to take the portable gen set to other property and use it as planned for some rural construction.
Please advise. Thanks in advance!
ArtF is offline   Reply With Quote
Old 06-15-2012, 10:54 PM   #2
dmxtothemax's Avatar
Rewards Points: 5,362
The loss at 30a over a 50 ft #10 cable is only 1.5v.
Not even worth worring about !
dmxtothemax is online now   Reply With Quote
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 07:42 PM
Need home plans for a simple barn home! RUMBLON General DIY Discussions 0 06-02-2011 03:05 PM
Moisture on windows baum Building & Construction 56 12-22-2009 05:39 PM
A facelift for your home Grumpy Remodeling 0 07-07-2004 07:43 PM
